[mapserver-users] Using OGL rendering instead of AGG
ramchandra
ram.chandra at vizexperts.com
Tue Jul 25 04:14:18 PDT 2017
Hi All,
I am trying to color classify a DEM by adding multiple styles to the
layer entry in the map file using the PIXEL value as the EXPRESSION. I am
trying to speedup the rendering of the styled layer. I tried using the
Hardware accelerated rendering through OpenGL. I have added the cmake flags
so that OpenGL binaries are loaded when building Mapserver.
I also made changes in the source code to enable the OGL Rendering by
setting the MACRO #USE_OGL to 1. I have also changed my OUTPUTFORMAT as
follows to trigger opengl rendering.
OUTPUTFORMAT
NAME "OGL_PNG24"
DRIVER "OGL/PNG"
IMAGEMODE RGB
END # OUTPUTFORMAT
In-spite of doing all these when i am sending the request it appends a new
OUTPUTFORMAT object with AGG Driver as follows.
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE RGB
TRANSPARENT FALSE
END # OUTPUTFORMAT
It also changes my OGL OUTPUTFORMAT by adding the additional fields MIMETYPE
and EXTENSION.
OUTPUTFORMAT
NAME "OGL_PNG24"
MIMETYPE "image/png; mode=24bit"
DRIVER "OGL/PNG"
EXTENSION "png"
IMAGEMODE RGB
TRANSPARENT FALSE
END # OUTPUTFORMAT
When I debug the code I see an error when the OGL output format block is
parsed.
The error says "OGL_PNG24 driver is not configured".
Can anyone point out what might me causing this error or how to enable
OpenGL based rendering.
Regards,
Ram
View this message in context: http://osgeo-org.1560.x6.nabble.com/Using-OGL-rendering-instead-of-AGG-tp5329120.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
