[mapserver-users] rotating a label 90 degrees.
Lime, Steve D (MNIT)
steve.lime at state.mn.us
Mon Jul 31 13:52:24 PDT 2017
I can’t think of anything offhand. If using PostGIS could you compute the angle and add 90? I think you could then use attribute binding on the result. Could pre-process data too. Otherwide we’d need an “angleoffset” parameters or something like that.
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Basques, Bob (CI-StPaul)
Sent: Monday, July 31, 2017 1:38 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] rotating a label 90 degrees.
All,
Is there and way to label a line with the ANGLE value set to AUTO, but to rotate the label by 90 degrees? I want to label a line by crossing perpendicular to the line vs aligned parallel.
Thanks
bobb
"In the end, it's not the years in your life that count. It's the life in your years.”
- Abraham Lincoln
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170731/f7108d7a/attachment-0001.html>
