[mapserver-users] Allow request in http and https
Kralidis, Tom (EC)
tom.kralidis at canada.ca
Tue May 2 16:31:48 PDT 2017
What happens when you do _not_ set ows_onlineresource? I think MapServer
will automagically determine the URL?
> -----Original Message-----
> From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On
> Behalf Of Andrea Peri
> Sent: 02 May 2017 18:26
> To: Richard Greenwood
> Cc: Mapserver-Users (mapserver-users at lists.osgeo.org)
> Subject: Re: [mapserver-users] Allow request in http and https
> mmm...
> Perhaps for the resource-online url could be better a setting like:
> "ows_resourceonline" "auto"
> Where "auto" mean that the mapserver retrieve the url (and the protocol used)
> from the request url of the getcapability request.
> This was the better solution.
> Infact if the client request on an https protocol it will return a capability files
> with all the request in https.
> And if the client request using an http protocol it will return a capability with
> http protocol.
> 2017-05-02 21:14 GMT+02:00 Richard Greenwood
> <richard.greenwood at gmail.com>:
> > If you really have to have two different wms_onlineresource and if
> > Steve's suggestion to leave out the protocol didn't work, then you
> > could create two ows URLs and use the map file's INCLUDE directive to
> > refer to the same map file just using different wms_onlineresource in the
> two.
> > On Tue, May 2, 2017 at 11:14 AM, Andrea Peri <aperi2007 at gmail.com>
> wrote:
> >> Hi Jukka,
> >> my trouble come from a webapplication using geotools lbrary.
> >> Seem that the geotools when try to connect to a WFS server (and I
> >> guess also to the WMS) start with a getcapabilities request and remap
> >> the getmap using it.
> >> We have many portal using http.
> >> Now there is a new portal using https, and it should access to the
> >> same wms services.
> >> So I have a portal using https that is using also http protocol.
> >> As I understand the web browser refuse to allow an http request when
> >> the father page is coming from an https request blocking them.
> >> A.
> >> 2017-05-02 16:50 GMT+02:00 Rahkonen Jukka (MML)
> >> <jukka.rahkonen at maanmittauslaitos.fi>:
> >> > Hi,
> >> > Actually your Mapserver will respond both to http and https
> >> > requests if your network let them both come through. OnlineResourse
> >> > has no effect at all for Mapserver, you can set it to
> >> > http://foo@bar if you wish. But WMS clients may have difficulties
> >> > if they really interpret the GetMap URL and use it for further
> >> > operations. QGIS and OpenJUMP have an override for using the same
> >> > base URL that was used for doing GetCapabililies and that might
> >> > suit for your case. OpenLayers, Leaflet etc. don't even parse
> GetCapabilities and http://foo@bar is totally OK for them.
> >> > -Jukka-
> >> > -----Alkuperäinen viesti-----
> >> > Lähettäjä: mapserver-users
> >> > [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Andrea
> >> > Peri
> >> > Lähetetty: 2. toukokuuta 2017 15:37
> >> > Vastaanottaja: mapserver-users at lists.osgeo.org
> >> > Aihe: [mapserver-users] Allow request in http and https
> >> > Hi,
> >> > I need to set a mapserver wms to responde both on an http url and
> >> > on an https url.
> >> > I try seting two time the
> >> > wms_onlineresource value:
> >> > "wms_onlineresource" "http://my-server/...."
> >> > "wms_onlineresource" "https://my-server/...."
> >> > But the getcapabilites response oonly the second value.
> >> > Is possible to set two url in the wms_onlineresource ?
> >> > Many thx.
> >> > Andrea Peri
> >> > qwerty àèìòù
> >> > _______________________________________________
> >> > mapserver-users mailing list
> >> > https://lists.osgeo.org/mailman/listinfo/mapserver-users
> >> Andrea Peri
> >> qwerty àèìòù
> > Richard W. Greenwood, PLS
> > www.greenwoodmap.com
> Andrea Peri
> qwerty àèìòù
