[mapserver-users] Issue in using MapServer WFS Filter
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Thu May 4 12:02:35 PDT 2017
I saved the states.shp file from the demo data directory that installs with GeoServer into PostGIS.
This query finds Kansas:
http://localhost:8060/cgi-bin/mapserv.exe?service=WFS&map=c:\ms4w_data\apps\states_pg.map&request=GetFeature&version=2.0.0&typeNames=ms:states_pg&FILTER=%3CFilter%3E%3CContains%3E%3CPropertyName%3EmsGeometry%3C/PropertyName%3E%3Cgml:Point%20srsName=%22urn:ogc:def:crs:EPSG::4326%22%3E%3Cgml:coordinates%3E40,-100%3C/gml:coordinates%3E%3C/gml:Point%3E%3C/Contains%3E%3C/Filter%3E
The SQL does contain the && comparison but is is not harmful.
My mapfile:
MAP
NAME "testname"
SIZE 800 800
EXTENT -180 -90 180 90
UNITS DD
IMAGECOLOR 20 250 250
SHAPEPATH "c:\ms4w\tmp"
IMAGETYPE "png"
OUTPUTFORMAT
NAME "geojson"
DRIVER "OGR/GEOJSON"
MIMETYPE "application/json; subtype=geojson"
FORMATOPTION "STORAGE=stream"
FORMATOPTION "FORM=SIMPLE"
END
WEB
METADATA
"ows_enable_request" "*"
"wms_bbox_extended" "true"
"wfs_return_srs_as_urn" "true"
"ows_srs" "CRS:84 EPSG:4326 EPSG:32634 EPSG:3857 EPSG:2923"
"wms_title" "MS 6.1.1 WMS from Spatialite"
"wfs_title" "MS 6.1.1 WFS from Spatialite"
"wfs_abstract" "ööää"
"wfs_onlineresource" "http://localhost:8060/cgi-bin/mapserv.exe?map=c:\ms4w\apps\wms-wfs.map"
# "wfs_use_default_extent_for_getfeature" "no"
END
END
DEBUG 10
CONFIG "PROJ_LIB" "C:/ms4w/proj/nad"
CONFIG "CPL_DEBUG" "ON"
CONFIG "SQLITE_LIST_ALL_TABLES" "TRUE"
CONFIG "MS_ERRORFILE" "c:/ms4w/tmp/debug.txt"
PROJECTION
"init=epsg:4326"
END
LAYER
NAME "states_pg"
STATUS DEFAULT
CONNECTIONTYPE POSTGIS
CONNECTION "dbname=xxx user=yyy"
DATA "geom from states using unique gid using srid=4326"
PROCESSING "CLOSE_CONNECTION=DEFER"
TYPE POLYGON
STATUS ON
PROJECTION
"init=epsg:4326"
END
OPACITY 50
METADATA
"ows_title" "states_pg" ##REQUIRED
"wfs_srs" "EPSG:4326" ## REQUIRED
"gml_include_items" "all" ## Optional (serves all attributes for layer)
# "gml_exclude_items" "STATE_NAME"
"gml_featureid" "gid" ## REQUIRED
"gml_types" "auto"
"wfs_getfeature_formatlist" "geojson"
END
CLASS
STYLE
COLOR 100 200 100
OUTLINECOLOR 0 0 0
END
LABEL
COLOR 150 150 150
OUTLINECOLOR 255 255 255
TYPE bitmap
SIZE small
POSITION UL
#TEXT "[STATE_FIPS]"
PARTIALS FALSE
END
LABEL
COLOR 150 150 150
TYPE bitmap
SIZE small
POSITION LL
#TEXT "[STATE_NAME]"
PARTIALS FALSE
END
END
END
END
-Jukka Rahkonen-
Lähettäjä: Kajod Sharma <kajod4u at yahoo.com>
Lähetetty: 4. toukokuuta 2017 12:20
Vastaanottaja: Rahkonen Jukka (MML); Jeff McKenna; mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] Issue in using MapServer WFS Filter
Still no much progress on it, is there anyone who faced the similar problem and got the solution?
Thanks.
Regards,
Kajod
To: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>; Jeff McKenna <jmckenna at gatewaygeomatics.com>; "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
Sent: Thursday, 27 April 2017 11:09 AM
Subject: Re: [mapserver-users] Issue in using MapServer WFS Filter
Thanks for valuable response.
I tried the solution suggested by you with putting NO for wfs_use_default_extent_for_getfeature. But still I can see default spatial filter in query.
I even tried with passing BBOX (which I don't want) in filter, but it's taking the default one...it's wierd :(
I'll try to get SQL for sample data and will share if I can.
Thanks.
Regards,
Kajod
From: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
To: Jeff McKenna <jmckenna at gatewaygeomatics.com>; "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
Sent: Wednesday, 26 April 2017 8:57 PM
When it comes to extra spatial filter, there is a brand new metadata item for switching it off. See http://mapserver.org/ogc/wfs_server.html
(Optional, since MapServer 7.0.4) Whether the MAP.EXTENT should be used in request to datasources in the absence of other spatial filter. This is the default behaviour, but this might affect performance in some use cases. In those cases, setting this item to NO will avoid he default spatial filter to be appended to the request. This is only implemented for OGR datasources.
However, with PostGIS the && query is fast. The weird part in your log
wkb_geometry &&
ST_GeomFromText('POLYGON((-0.999462804873474
-1.00102606014116,-0.999462804873474
-1.00102606014116))
means that the layer extent is not set correctly or Mapserver can't get is correctly from PostGIS which means data error on that side. For sure using the non-existing keyword wfs_boundingbox is not right. See what can be used from http://mapserver.org/ogc/wfs_server.html.
When you play with spatial filters I recommend to start by using the native SRS for the feature type in filters. Non-native SRS in filter should be transformed by the server but it is error prone. Your filter is also also a little bit fuzzy. gml:coordinates belongs to GML2 and was removed from GML2. But you are using service version 2.0 that defaults to GML3. Is the meaning that your filter is GML2 or GML3? That is a big difference because in the first case the axis order of EPSG:4326 coordinates is longitude-latitude but in the latter it is latitude-longitude. Do you search near the equator or from somewhere in Europe?
<PropertyName>wkb_Geometry</PropertyName>
<gml:Point srsName="urn:ogc:def:crs:EPSG::4326">
<gml:coordinates>0.112034,53.567972</gml:coordinates>
</gml:Point>
One more thing, "wfs_srs" metadata takes only one SRS, not a list.
If you send SQL for CREATE TABLE and for inserting one polygon into the table, and WFS filter you are using in your trials I thing I could find some time for testing.
-Jukka Rahkonen-
________________________________________
Hi Kajod,
If you are using PostGIS, then I would set the 'wfs_extent' metadata at
the layer level of the mapfile (it looks like you tried that, with an
odd 'wfs_boundingbox' parameter): please review the syntax of the
wfs_extent parameter at
http://www.mapserver.org/ogc/wfs_server.html#layer-object
Then, next step is always to execute a GetCapabilities request and go
through that response and make sure there are no "WARNING" messages, and
make the changes in the mapfile to remove those warnings if necessary...
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2017-04-26 10:42 AM, Kajod Sharma wrote:
> Hi,
> Greetings!
> I hope this is a right platform to discuss my query regarding FILTER
> applied on MapServer WFS.
> I'm new in this area and exploring some features of MapServer. I want to
> use GetFeature request of WFS to get features applied on any location on
> map. I'm using "MapServer version 7.0.4 (MS4W 3.2.1)" and trying to
> apply filter "Contains" for it.
> I can see two problems when it applies Filter query on PostGIS:
> 1. It looks it adds an extra default geospatial filter in it while
> making a query to PostGIS. This default spatial filter is not stopping
> to return any result from PostGIS. Is there any way to exclude this
> default filter?
> 2. It seems Contains coordinates are not transformed properly according
> to SRS of data in PostGIS.
> I've tries with different projection in map file and request message
> with no success.
> Supporting data to give your input on my queries:
> WFS request
> Formatted Version:
> http://localhost/cgi-bin/mapserv.exe?
> service=WFS&
> map=C:/Data/MapServerWFSSample.map&
> request=GetFeature&
> version=2.0.0&
> typeName=SampleLayer&
> FILTER=<Filter xmlns="http://www.opengis.net/ogc"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:ms="http://mapserver.gis.umn.edu/mapserver">
> <*Contains*>
> </gml:Point>
> </*Contains*>
> </Filter>
> PostGIS query [Could see in log file]:
> msPostGISLayerWhichShapes query: select
> "Attribute1","Attribute2","Attribute3",encode(ST_AsBinary(ST_Force2D("wkb_geometry"),'NDR'),'hex')
> as geom from SampleGeoDataTable where */wkb_geometry &&
> -1.00102606014116))',find_srid('','SampleGeoDataTable','wkb_geometry'))/* and
> (st_contains(wkb_geometry,ST_GeomFromText('POINT
> (*/7853690.3631838141000000 -5506204.5232773330000000/*)')) = TRUE)
> Similar WFS query to GeoServer works perfectly.
> It would be very helpful if someone can help me on it. Thanks a lot in
> advance.
> Map File looks like:
> MAP
> NAME "Sample_WMS"
> CONFIG "PROJ_LIB" "C:\ms4w\proj\nad"
> CONFIG "MS_ERRORFILE" "C:/Data/ms_tmp/ms_error.txt"
> CONFIG "PROJ_DEBUG" "ON"
> STATUS ON
> PROJECTION
> "init=epsg:27700"
> END
> WEB
> IMAGEPATH "C:/Data/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> METADATA
> "wfs_enable_request" "*"
> "wfs_title" "My Global Map WFS Server"
> "wfs_srs" "EPSG:4326 EPSG:900913 EPSG:27700"
> "wfs_boundingbox" "EPSG:27700 749.099975585938 -90036.5
> 660460.875 1227306.5"
> END
> END
> LAYER
> NAME "SampleLayer"
> STATUS DEFAULT
> TYPE POLYGON
> PROJECTION
> "init=epsg:27700"
> END
> CONNECTION "host=localhost port=5432 dbname=SampleGeoDataTable
> user=postgres password=hahaha"
> DATA "wkb_geometry from SampleLayer"
> CLASS
> STYLE
> COLOR 0 100 255
> OUTLINECOLOR 0 0 0
> END
> END
> METADATA
> "wfs_title" "Sample WFS"
> "wfs_srs" "EPSG:27700 EPSG:4326 EPSG:900913"
> END
> END
> END
> Regards,
> Kajod
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170504/0097d6cd/attachment-0001.html>
