[mapserver-users] OGR connection failed - OCI
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue May 23 07:20:37 PDT 2017
On 2017-05-23 11:13 AM, GeoLady wrote:
> Hi,
> thank for your reply. I have tried your connect string format before.
> For connect string in this format CONNECTION "OCI:username/password at SID" I
> need TNS_ADMIN defined.
> Instant oracle client has no tnsnames.ora. I created one:
> <addressname> =
> (DESCRIPTION =
> (ADDRESS_LIST =
> (ADDRESS = (PROTOCOL = TCP)(Host = <hostname>)(Port = <port>))
> (CONNECT_DATA =
> (SERVICE_NAME = <service_name>)
> And I set environment variable>
> TNS_ADMIN=d:\oracle\instantclient_12_1-x64\network\admin\
> ORACLE_HOME=d:\oracle\instantclient_12_1-x64\
> When I do ogrinfo OCI:username/password at SID, I get error:
> C:\Users\admin>ogrinfo OCI:username/password at SID
> ERROR 1: in <unnamed>
> FAILURE:
> Unable to open datasource `OCI:username/password at SID' with the following
> drivers.
> -> netCDF
> -> AmigoCloud
> -> OCI
> -> PCIDSK
> So I deleted both environment variables and I used connect string
> format:"OCI:user/pass at host:port/SID"
> It works with ogrinfo OCI:user/pass at host:port/SID but it doesn't work with
> MapServer layer.
Please see my previous message, I believe your initial syntax is correct
(sorry for my initial confusion).
It sounds to me like your web server is not loading that OGR dll.
For something working, you can try MS4W locally and then replicate that
in another web server environment, as it has good documented steps for
connecting to Oracle at
http://ms4w.com/README_INSTALL.html#steps-to-enable-oracle-10g-or-11g-or-12c-support-in-ms4w
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
