[mapserver-users] GetCapabilities error
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Tue May 30 06:52:00 PDT 2017
Hi GeoLady, (nice alias)
first of all you don't get the mapserv.exe file downloaded, it is the
capabilities-doc which is named mapserv.exe by your webserver. I don't
know how to to change this, but it shouldn't be the problem.
Within the downloaded document, below the gdal-messages, the
capabilities-doc begins with
>> <?xml version='1.0' encoding="UTF-8" standalone="no" ?>
and it looks good.
As the lines
>> GDAL: Auto register \\?\D:\MapServer\scripts\gdalplugins\gdal_BAG.dll
look like gdal-debug-messages I would try seting
>> CONFIG "CPL_DEBUG" "ON"
to
>> CONFIG "CPL_DEBUG" "Off"
(or just delete the line).
Regards, Jörg aka MapServerGuy ;)
Am 30.05.2017 um 13:58 schrieb GeoLady:
> Hi,
> I have problem with GetCapabilities in WMS in MapServer. I try it in our
> intranet for now, so 192.168.0.127 is not accesible from internet.
> I try this url in QGIS or in my browser:
> http://192.168.0.127/mapserver/scripts/mapserv.exe?map=D:\MapServer\map\wmstest.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
> But what I get is just the mapserv.exe which gets downloaded every time. And
> there is this error:
> GDAL: Auto register \\?\D:\MapServer\scripts\gdalplugins\gdal_BAG.dll using
> GDALRegister_BAG.
> GDAL: Auto register \\?\D:\MapServer\scripts\gdalplugins\gdal_FITS.dll using
> GDALRegister_FITS.
> GDAL: Auto register \\?\D:\MapServer\scripts\gdalplugins\gdal_GEOR.dll using
> GDALRegister_GEOR.
> GDAL: Auto register \\?\D:\MapServer\scripts\gdalplugins\gdal_GMT.dll using
> GDALRegister_GMT.
> GDAL: Auto register \\?\D:\MapServer\scripts\gdalplugins\gdal_HDF4.dll using
> GDALRegister_HDF4.
> GDAL: Auto register \\?\D:\MapServer\scripts\gdalplugins\gdal_HDF4Image.dll
> using GDALRegister_HDF4Image.
> GDAL: Auto register \\?\D:\MapServer\scripts\gdalplugins\gdal_HDF5.dll using
> GDALRegister_HDF5.
> GDAL: Auto register \\?\D:\MapServer\scripts\gdalplugins\gdal_HDF5Image.dll
> using GDALRegister_HDF5Image.
> GDAL: Auto register \\?\D:\MapServer\scripts\gdalplugins\gdal_KEA.dll using
> GDALRegister_KEA.
> GDAL: Auto register \\?\D:\MapServer\scripts\gdalplugins\gdal_MG4Lidar.dll
> using GDALRegister_MG4Lidar.
> GDAL: Auto register \\?\D:\MapServer\scripts\gdalplugins\gdal_MrSID.dll
> using GDALRegister_MrSID.
> GDAL: Auto register \\?\D:\MapServer\scripts\gdalplugins\gdal_netCDF.dll
> using GDALRegister_netCDF.
> GDAL: Auto register \\?\D:\MapServer\scripts\gdalplugins\ogr_AmigoCloud.dll
> using RegisterOGRAmigoCloud.
> GDAL: Auto register \\?\D:\MapServer\scripts\gdalplugins\ogr_OCI.dll using
> RegisterOGROCI.
> GNM: GNMRegisterAllInternal
> GNM: RegisterGNMFile
> GNM: RegisterGNMdatabase
> <!DOCTYPE WMT_MS_Capabilities SYSTEM
> "http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
> <!ELEMENT VendorSpecificCapabilities EMPTY>
> <WMT_MS_Capabilities version="1.1.1">
> <Service>
> <Name>OGC:WMS</Name>
> <Title>Test WMS MVi</Title>
> <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
> xlink:href="http://192.168.0.127/mapserver/scripts/mapserv.exe?map=D:\MapServer\map\wmstest.map?"/>
> <ContactInformation>
> </ContactInformation>
> </Service>
> <Capability>
> <Request>
> <GetCapabilities>
> <Format>application/vnd.ogc.wms_xml</Format>
> <DCPType>
> <HTTP>
> <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
> xlink:href="http://192.168.0.127/mapserver/scripts/mapserv.exe?map=D:\MapServer\map\wmstest.map?"/></Get>
> <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
> xlink:href="http://192.168.0.127/mapserver/scripts/mapserv.exe?map=D:\MapServer\map\wmstest.map?"/></Post>
> </HTTP>
> </DCPType>
> </GetCapabilities>
> <GetMap>
> <Format>image/png</Format>
> <Format>image/jpeg</Format>
> <Format>image/png; mode=8bit</Format>
> <Format>application/x-pdf</Format>
> <Format>image/svg+xml</Format>
> <Format>image/tiff</Format>
> <Format>application/vnd.google-earth.kml+xml</Format>
> <Format>application/vnd.google-earth.kmz</Format>
> <DCPType>
> <HTTP>
> </HTTP>
> </DCPType>
> </GetMap>
> <GetFeatureInfo>
> <Format>text/html</Format>
> <Format>application/vnd.ogc.gml</Format>
> <Format>text/plain</Format>
> <DCPType>
> <HTTP>
> </HTTP>
> </DCPType>
> </GetFeatureInfo>
> <DescribeLayer>
> <Format>text/xml</Format>
> <DCPType>
> <HTTP>
> </HTTP>
> </DCPType>
> </DescribeLayer>
> <GetLegendGraphic>
> <DCPType>
> <HTTP>
> </HTTP>
> </DCPType>
> </GetLegendGraphic>
> <GetStyles>
> <DCPType>
> <HTTP>
> </HTTP>
> </DCPType>
> </GetStyles>
> </Request>
> <Exception>
> <Format>application/vnd.ogc.se_xml</Format>
> <Format>application/vnd.ogc.se_inimage</Format>
> <Format>application/vnd.ogc.se_blank</Format>
> </Exception>
> <VendorSpecificCapabilities />
> <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1"
> RemoteWFS="0"/>
> <Layer>
> <Name>MS</Name>
> <Abstract>MS</Abstract>
> <SRS>EPSG:2065</SRS>
> <LatLonBoundingBox minx="19.0997" miny="48.5713" maxx="19.1463"
> maxy="48.583" />
> <BoundingBox SRS="EPSG:2065"
> minx="-422441" miny="-1.24647e+006" maxx="-419074"
> maxy="-1.24543e+006" />
> <Layer queryable="0" opaque="0" cascaded="0">
> <Name>ulice</Name>
> <Title>UlicnaSiet</Title>
> <LatLonBoundingBox minx="19.1138" miny="48.572" maxx="19.1316"
> maxy="48.5818" />
> minx="-421400" miny="-1.24648e+006" maxx="-420159"
> maxy="-1.24548e+006" />
> </Layer>
> </Layer>
> </Capability>
> </WMT_MS_Capabilities>
> When I try this url in my browser, it works fine:
> SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=ULICE&STYLES=&SRS=EPSG:2065&
> BBOX=-422441,-1246473,-419074,-1245427&WIDTH=600&HEIGHT=300&FORMAT=image/png
> When I try shp2img -m d:\MapServer\map\wmstest.map -o wms.png, it works too.
> Here is my mapfile:
> MAP
> EXTENT -422441 -1246473 -419074 -1245427
> SIZE 600 300
> FONTSET "D:\MapServer\fonts\font.list"
> CONFIG "PROJ_LIB" "D:\MapServer\scripts\proj\nad"
> CONFIG "MS_ERRORFILE" "D:\MapServer\tmp\ms_error.txt"
> CONFIG "PROJ_DEBUG" "ON"
> DEBUG 5
> MAXSIZE 100000
> SHAPEPATH "D:\MapServer\data"
> WEB
> IMAGEPATH "/MapServer/tmp/"
> IMAGEURL "/MapServer/tmp/"
> #TEMPLATE "d:\MapServer\mm.html"#
> METADATA
> "wms_title" "Test WMS MVi"
> "wms_onlineresource"
> "wms_enable_request" "*"
> "wms_srs" "EPSG:2065"
> "wms_feature_info_mime_type" "text/html"
> "wms_format" "image/png"
> END
> END
> PROJECTION
> "init=epsg:2065"
> END
> LAYER
> NAME ulice
> DATA ulice
> STATUS ON
> TYPE LINE
> ENCODING "UTF-8"
> METADATA
> "wms_title" "UlicnaSiet"
> END
> PROJECTION
> "init=epsg:2065"
> END
> LABELITEM "N_GM_U"
> CLASS
> NAME "Uličná sieť"
> STYLE
> COLOR 255 128 0
> END
> LABEL
> COLOR 132 31 31
> TYPE TRUETYPE
> FONT arial
> SIZE 8
> ANTIALIAS TRUE
> POSITION CL
> PARTIALS FALSE
> MINDISTANCE 300
> BUFFER 4
> STYLE # since to version 6
> GEOMTRANSFORM 'labelpnt'
> COLOR 218 218 218
> OFFSET 2 2
> END # STYLE
> END # label
> END #class
> END #layer
> END
> Can someone help, thanks a lot.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/GetCapabilities-error-tp5322278.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Viele Grüße,
Jörg Thomsen
AGIT 2017
5.-7. Juli 2017 in Salzburg
Besuchen Sie uns an Stand Nr. 31
www.agit.at
Jörg Thomsen
WhereGroup GmbH & Co. KG
Gillweg 3
14193 Berlin
Germany
Fon: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 89 09 53 21
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the MapServer-users
