[mapserver-users] Draw roads WITHOUT anti-aliasing
Eichner, Andreas - SID
Andreas.Eichner at sid.sachsen.de
Mon Nov 6 23:28:04 PST 2017
> -----Ursprüngliche Nachricht-----
> Von: Erik H [mailto:erik.h11.01 at gmail.com]
> Gesendet: Montag, 6. November 2017 17:09
> An: Eichner, Andreas - SID
> Cc: mapserver-users at lists.osgeo.org
> Betreff: Re: [mapserver-users] Draw roads WITHOUT anti-aliasing
> Thanks again - I'm getting there. I installed libxml2-devel and added
> flags for LIBXML2 and WMS, and now I can compile 'master'.
> I was also able to merge it with my branch and compile it without
> problems. Rebasing my branch onto the latest and greatest commit in
> 'master' worked as well.
That's great - glad to hear this!
> Was unable to push my changes to the Github repo in order to create a
> PR, though.
> The 'WorkingWithGit' Wiki page says that I have to checkout 'master',
> merge my branch, and push it back; this seems a bit strange to me (I
> expected to have to push my own branch), and it does not seem to work
> anyway:
> 403 Forbidden while accessing https://erik-
> h1 at github.com/mapserver/mapserver.git/info/refs
> Same error when trying to push my own branch. Do I need to be granted
> access first, or should I somehow create a PR first?
AFAIK only the core devs have write access to the mapserver/* repos. The usual way is to create an account on GitHub, fork off the MapServer-Repo, clone a local copy from this, do the changes, merge with latest master, push it back to your GitHub repo and create a PR on GitHub.
Not sure but I believe after creating your account and creating the fork you can simply set the '"pushurl' for '[remote "origin"]' in .git/config to your repo and push:
[remote "origin"]
fetch = +refs/heads/*:refs/remotes/origin/*
url = https://github.com/mapserver/mapserver
pushurl = https://github.com/<your_github_account_here>/mapserver.git
You may also ask on the mapserver-dev mailing list for additional help to get it to work.
HTH
