[mapserver-users] Σχετ: Labels moving
Stefanos Anastasiou
emperor_stef at yahoo.gr
Sat Nov 11 11:14:52 PST 2017
Hello Steve, I come to this old e-mail because I'noticed in a new app I'm building, that although this was working for polygons, it's still not working in shapefiles of TYPE line... at least here. Although I set on the layer level PROCESSING "LABEL_NO_CLIP=False" the labels on my roads are still moving.
Any hint on this?
mapserver version:
MapServer version 7.0.6 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Στις 3:56 μ.μ. Τρίτη, 29 Νοεμβρίου 2016, ο/η "Lime, Steve D (MNIT)" <Steve.Lime at state.mn.us> έγραψε:
That is normal. Label position is computed based on the clipped geometry. There is a LAYER processing directive called LABEL_NO_CLIP available if you want to avoid that behavior. --Steve
_______________________________________
From: mapserver-users [mapserver-users-bounces at lists.osgeo.org] on behalf of Stefanos Anastasiou [emperor_stef at yahoo.gr]
Sent: Monday, November 28, 2016 2:09 PM
To: MapserverList OSGEO
Subject: [mapserver-users] Labels moving
Hello list,
I'm drawing some features and render them with OpenLayers controls. As I pan to various directions I notice that the labels are moving every time I pan. Example: A label of a polygon is in the center when the map is first loaded. When I pan to the right, the label is also moving to the right. It's like it's trying to fit in the image. Is this normal or am I missing something?
-Stefanos
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20171111/11834353/attachment.html>
