[mapserver-users] PDF output with layers
Carlos Ruiz
boolean10001 at yahoo.com
Mon Sep 4 07:20:13 PDT 2017
I'm currently exploring PDF generation from Mapserver and I have noticed that no layers appear to be toggled. First I thought this was because the layer CLASS section has no name (as it happens when legend is generated), but it is not.
gdalinfo test.pdf does not show layers information.
Does anybody know how to configure a MAP file to include layers in the PDF output ?
Here is test.map contents:
MAP
NAME "test"
EXTENT 657024 2277645 687240 2294128
SIZE 800 600
OUTPUTFORMAT
NAME "pdf"
DRIVER CAIRO/PDF
MIMETYPE "application/x-pdf"
IMAGEMODE RGB
EXTENSION "pdf"
FORMATOPTION "GEO_ENCODING=ISO32000"
END
PROJECTION
"init=EPSG:32613"
END
STATUS ON
LAYER
NAME "Landsat 8"
CONNECTION "http://localhost/cgi-bin/landsat8.exe"
CONNECTIONTYPE WMS
TYPE RASTER
STATUS ON
METADATA
"wms_name" "Landsat 8"
"wms_srs" "EPSG:32613"
"wms_server_version" "1.0.0"
"wms_format" "image/jpeg"
END
END
LAYER
NAME "Colonias"
CONNECTION "..."
CONNECTIONTYPE POSTGIS
DATA "geom FROM colonias_amg"
TYPE POLYGON
CLASS
NAME "Colonias"
STYLE
COLOR 255 200 150
OUTLINECOLOR 0 0 0
END
END
COMPOSITE
OPACITY 35
END
STATUS ON
END
END
Thanks in advance
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170904/b5a6c5a9/attachment.html>
