[mapserver-users] [External] Re: serving sparse DTED with WCS
Burkhardt, Glenn B UTAS
Glenn.Burkhardt at utas.utc.com
Fri Apr 6 08:17:14 PDT 2018
This works perfectly for me. Missing 1x1 deg tiles from a bounding box are correctly reported as missing, and if there is missing data within a tile, it also is reported as missing. Thanks!
Suggestion for improvement: when the data file supplied to Mapserver is Geotiff, and a " NoData Value" is supplied, automatically use it as a null value for the layer.
-----Original Message-----
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: Thursday, April 5, 2018 10:02
To: mapserver-users at lists.osgeo.org
Cc: Burkhardt, Glenn B UTAS <Glenn.Burkhardt at utas.utc.com>
Subject: [External] Re: [mapserver-users] serving sparse DTED with WCS
On mercredi 4 avril 2018 19:51:56 CEST Burkhardt, Glenn B UTAS wrote:
> DTED data is notoriously sparse. If one combines all the files in a
> DTED dataset into a single Geotiff file using something like "
> gdalwarp -co TILED=YES */*.dt2 dted2.tif"
> But GDAL will build a bounding box that's square with the world, and
> there might not be data for every 1x1 deg section of the bounding box.
> When this happens, Mapserver fills in the missing data with zeros.
> Additionally, there might be data missing from within a 1x1 deg DTED
> file, and it is marked with a NODATA flag of -32767.
> Is there some way for Mapserver to communicate to a client where data
> is missing? I can't find anything in the coverage information
> provided to a WCS 1.0.0 client.
Glenn,
You can define in the LAYER.METADATA section things like for WCS 1.0 and WCS
1.1
"wcs_rangeset_nullvalue" "-32767"
Actually I see this wasn't documented. I've just added it in http://mapserver.org/ogc/wcs_server.html
For WCS 2, use "wcs_nilvalues"
Even
Spatialys - Geospatial professional services http://www.spatialys.com/en/home/
