[mapserver-users] MapCache Time Dimension
coastalrocket
andy at planetnomad.com
Tue Aug 14 02:38:13 PDT 2018
Hi there,
I'm having issue with MapCache with a time dimension. The image returned is
blank with "no tiles containing image data could be retrieved to create map
(not in cache, and/or no source configured)" in my apache error log.
When I hit the WMS-T directly I get images containing data so I'm confident
that this working as intended.
Without the dimensions section in my MapCache tileset definition it returns
an image with the default time. Default time is set in my .map file.
So I've concentrated on checking the dimensions section on my configuration.
Like others I'm sure I've taken copy from
https://mapserver.org/mapcache/dimensions.html. I've tested the query in
sqlite and that appears ok. The table definition is CREATE TABLE
random_crime_time(the_date date); which contains a distinct datetime values
from my spatial dataset ordered by the_date desc. I hope this sounds
reasonable.
Here's the tileset definition:
<tileset name="random_crime">
<source>random_crime_wms</source>
<dimensions>
<assembly_type>stack</assembly_type>
<store_assemblies>true</store_assemblies>
<subdimensions_read_only>false</subdimensions_read_only>
<dimension name="time" default="2011" type="time">
<dbfile>E:\\ms4w\\tmp\\random_crime.db</dbfile>
<query>SELECT strftime("%Y-%m-%dT%H:%M:%SZ",the_date) FROM
random_crime_time WHERE the_date >=
datetime(:start_timestamp,"unixepoch") AND the_date <=
datetime(:end_timestamp,"unixepoch") ORDER BY the_date DESC</query>
</dimension>
</dimensions>
<cache>time_disk_cache</cache>
<format>png_best</format>
<grid>bng_grid</grid>
<metatile>5 5</metatile>
<metabuffer>10</metabuffer>
<expires>3600</expires>
</tileset>
I'm running 3.2.7 ms4w: MapServer CGI 7.0.7 and MapCache 1.6.1. My next
thoughts are to work out how to place a trace on sqlite.
Any pointers much appreciated
AndyB
Here's the apache access log:
::1 - - [14/Aug/2018:10:36:18 +0100] "GET
/mapcache?TIME=2011-01-10&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=random_crime&STYLES=&WIDTH=800&HEIGHT=600&FORMAT=image/png&SRS=EPSG:27700&TILED=true&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE&BBOX=484031.98297410696977749,158902.34551714232657105,492935.18127151770750061,164805.54381455303519033
HTTP/1.1" 200 3134
Here's the apache error log:
[Tue Aug 14 10:36:16.879152 2018] [:debug] [pid 4180:tid 972]
mod_mapcache.c(448): [client ::1:49513] mapcache quick handler hook on uri
/mapcache
[Tue Aug 14 10:36:16.879152 2018] [authz_core:debug] [pid 4180:tid 972]
mod_authz_core.c(806): [client ::1:49513] AH01626: authorization result of
Require all granted: granted
<RequireAny>: granted
[Tue Aug 14 10:36:16.880103 2018] [:debug] [pid 4180:tid 1012]
mod_mapcache.c(164): [client ::1:49513] checking for tile
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/236/000/000/077.png
[Tue Aug 14 10:36:16.880103 2018] [:debug] [pid 4180:tid 1016]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/236/000/000/080.png
[Tue Aug 14 10:36:16.880103 2018] [:debug] [pid 4180:tid 1028]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/240/000/000/080.png
[Tue Aug 14 10:36:16.884154 2018] [:debug] [pid 4180:tid 1020]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/240/000/000/077.png
[Tue Aug 14 10:36:16.888155 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/236/000/000/078.png
[Tue Aug 14 10:36:16.891151 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/236/000/000/079.png
[Tue Aug 14 10:36:16.895154 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/237/000/000/077.png
[Tue Aug 14 10:36:16.898153 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/237/000/000/078.png
[Tue Aug 14 10:36:16.901154 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/237/000/000/079.png
[Tue Aug 14 10:36:16.904121 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/237/000/000/080.png
[Tue Aug 14 10:36:16.907198 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/238/000/000/077.png
[Tue Aug 14 10:36:16.912155 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/238/000/000/078.png
[Tue Aug 14 10:36:16.915154 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/238/000/000/079.png
[Tue Aug 14 10:36:16.918153 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/238/000/000/080.png
[Tue Aug 14 10:36:16.920151 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/239/000/000/077.png
[Tue Aug 14 10:36:16.924153 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/239/000/000/078.png
[Tue Aug 14 10:36:16.927154 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/239/000/000/079.png
[Tue Aug 14 10:36:16.930153 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/239/000/000/080.png
[Tue Aug 14 10:36:16.932151 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/240/000/000/078.png
[Tue Aug 14 10:36:16.935153 2018] [:debug] [pid 4180:tid 972]
E:/ms4w/tmp/ms_tmp/cache//random_crime/bng_grid/2011-01-10/17/000/000/240/000/000/079.png
[Tue Aug 14 10:36:16.939154 2018] [:error] [pid 4180:tid 972] [client
::1:49513] no tiles containing image data could be retrieved to create map
[Tue Aug 14 10:36:17.215152 2018] [mpm_winnt:notice] [pid 1456:tid 520]
AH00428: Parent: child process 4180 exited with status 3221225477 --
Restarting.
[Tue Aug 14 10:36:18.147130 2018] [:info] [pid 1456:tid 520] loaded mapcache
configuration file from E:/ms4w/apps/mapcache/mapcache.xml on endpoint
/mapcache
[Tue Aug 14 10:36:18.157127 2018] [mpm_winnt:notice] [pid 1456:tid 520]
AH00455: Apache/2.4.33 (Win32) mod_fcgid/2.3.9 mod-mapcache/1.6.1 configured
-- resuming normal operations
AH00456: Server built: Apr 30 2018 12:56:38
[Tue Aug 14 10:36:18.157127 2018] [core:notice] [pid 1456:tid 520] AH00094:
Command line: 'E:\\ms4w\\Apache\\bin\\httpd.exe -d E:/ms4w/Apache'
[Tue Aug 14 10:36:18.157127 2018] [core:debug] [pid 1456:tid 520]
log.c(1567): AH02639: Using SO_REUSEPORT: no (0)
[Tue Aug 14 10:36:18.160128 2018] [mpm_winnt:notice] [pid 1456:tid 520]
AH00418: Parent: Created child process 4268
[Tue Aug 14 10:36:18.160128 2018] [mpm_winnt:debug] [pid 1456:tid 520]
mpm_winnt.c(429): AH00402: Parent: Sent the scoreboard to the child
[Tue Aug 14 10:36:18.434129 2018] [:info] [pid 4268:tid 356] loaded mapcache
/mapcache
[Tue Aug 14 10:36:18.464126 2018] [:info] [pid 4268:tid 356] loaded mapcache
/mapcache
[Tue Aug 14 10:36:18.474126 2018] [mpm_winnt:debug] [pid 4268:tid 356]
mpm_winnt.c(1718): AH00453: Child process is running
[Tue Aug 14 10:36:18.474126 2018] [:debug] [pid 4268:tid 356]
mod_mapcache.c(316): creating a child process mapcache connection pool on
server www.example.com for alias /mapcache
mpm_winnt.c(343): AH00391: Child: Retrieved our scoreboard from the parent.
[Tue Aug 14 10:36:18.474126 2018] [mpm_winnt:debug] [pid 1456:tid 520]
mpm_winnt.c(512): AH00408: Parent: Duplicating socket 432 ([::]:8080) and
sending it to child process 4268
mpm_winnt.c(465): AH00403: Child: Waiting for data for listening socket
0.0.0.0:8080
mpm_winnt.c(512): AH00408: Parent: Duplicating socket 456 (0.0.0.0:8080) and
mpm_winnt.c(531): AH00411: Parent: Sent 2 listeners to child 4268
[Tue Aug 14 10:36:18.475127 2018] [mpm_winnt:debug] [pid 4268:tid 356]
[::]:8080
mpm_winnt.c(490): AH00407: Child: retrieved 2 listeners from parent
child.c(947): AH00352: Child: Acquired the start mutex.
[Tue Aug 14 10:36:18.475127 2018] [mpm_winnt:notice] [pid 4268:tid 356]
AH00354: Child: Starting 64 worker threads.
[Tue Aug 14 10:36:18.476096 2018] [mpm_winnt:debug] [pid 4268:tid 836]
child.c(411): AH00334: Child: Accept thread listening on 0.0.0.0:8080 using
AcceptFilter none
[Tue Aug 14 10:36:18.476096 2018] [:debug] [pid 4268:tid 824]
mod_mapcache.c(448): [client ::1:49514] mapcache quick handler hook on uri
/mapcache
[Tue Aug 14 10:36:18.477126 2018] [authz_core:debug] [pid 4268:tid 824]
mod_authz_core.c(806): [client ::1:49514] AH01626: authorization result of
[Tue Aug 14 10:36:18.477126 2018] [:debug] [pid 4268:tid 864]
mod_mapcache.c(164): [client ::1:49514] checking for tile
[Tue Aug 14 10:36:18.477126 2018] [:debug] [pid 4268:tid 924]
[Tue Aug 14 10:36:18.478091 2018] [mpm_winnt:debug] [pid 4268:tid 1028]
child.c(411): AH00334: Child: Accept thread listening on [::]:8080 using
AcceptFilter none
[Tue Aug 14 10:36:18.478091 2018] [:debug] [pid 4268:tid 916]
[Tue Aug 14 10:36:18.478091 2018] [:debug] [pid 4268:tid 928]
[Tue Aug 14 10:36:18.478091 2018] [:debug] [pid 4268:tid 824]
[Tue Aug 14 10:36:18.479127 2018] [:debug] [pid 4268:tid 824]
[Tue Aug 14 10:36:18.859100 2018] [mpm_winnt:notice] [pid 1456:tid 520]
AH00428: Parent: child process 4268 exited with status 3221225477 --
Restarting.
[Tue Aug 14 10:36:19.193061 2018] [:info] [pid 1456:tid 520] loaded mapcache
/mapcache
[Tue Aug 14 10:36:19.202104 2018] [mpm_winnt:notice] [pid 1456:tid 520]
[Tue Aug 14 10:36:19.202104 2018] [core:notice] [pid 1456:tid 520] AH00094:
[Tue Aug 14 10:36:19.202104 2018] [core:debug] [pid 1456:tid 520]
[Tue Aug 14 10:36:19.205101 2018] [mpm_winnt:notice] [pid 1456:tid 520]
AH00418: Parent: Created child process 1648
[Tue Aug 14 10:36:19.205101 2018] [mpm_winnt:debug] [pid 1456:tid 520]
[Tue Aug 14 10:36:19.489101 2018] [:info] [pid 1648:tid 356] loaded mapcache
/mapcache
[Tue Aug 14 10:36:19.519101 2018] [:info] [pid 1648:tid 356] loaded mapcache
/mapcache
[Tue Aug 14 10:36:19.529102 2018] [mpm_winnt:debug] [pid 1648:tid 356]
[Tue Aug 14 10:36:19.530101 2018] [:debug] [pid 1648:tid 356]
[Tue Aug 14 10:36:19.530101 2018] [mpm_winnt:debug] [pid 1648:tid 356]
0.0.0.0:8080
[Tue Aug 14 10:36:19.530101 2018] [mpm_winnt:debug] [pid 1456:tid 520]
sending it to child process 1648
mpm_winnt.c(531): AH00411: Parent: Sent 2 listeners to child 1648
[Tue Aug 14 10:36:19.531099 2018] [mpm_winnt:debug] [pid 1648:tid 356]
[::]:8080
[Tue Aug 14 10:36:19.531099 2018] [mpm_winnt:notice] [pid 1648:tid 356]
[Tue Aug 14 10:36:19.534049 2018] [mpm_winnt:debug] [pid 1648:tid 876]
AcceptFilter none
[Tue Aug 14 10:36:19.534049 2018] [mpm_winnt:debug] [pid 1648:tid 940]
AcceptFilter none
Sent from: http://osgeo-org.1560.x6.nabble.com/Mapserver-User-f4226646.html
