[mapserver-users] labels only displaying across the center of the map (not on the top or bottom)
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Aug 21 13:16:01 PDT 2018
You might find that readers would like to see a map image example (if
so, be sure to always use external service such as
https://pasteboard.co/ and include that link in your message) or a
mapfile or mapfile layer (if so, be sure to always use an external
service such as https://pastebin.com/ and include that link in your
message).
Following those steps will always ensure that your responder's email
attempt will not be blocked by the mail system.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2018-08-21 4:36 PM, Mark Volz wrote:
> Hello,
> We noticed on my map that labels were only displaying across the center
> 1/3 of the map and not towards the top or bottom of the map for one
> particular layer in the map. After changing PARTIALS from FALSE to TRUE
> the map was able to display all the labels as expected, which is good.
> However I am curious as to what caused the labels to only display across
> the center 1/3 of the map in the first place. Please let me know if
> there is anything I can look at to correct this issue.
> Thank You!
