[mapserver-users] OGR GeoJSON Layers...
Lime, Steve D (MNIT) steve.lime at state.mn.us
Fri Dec 7 09:33:39 PST 2018
It may be my GDAL version, it’s a tad older. I will try and update that. Might be worth thininking about supporting runtime subs in the OGR url to pass extent values easily - where MapServer does the substitution using computed values. Kinda like the bbox hack for PostGIS.
Sent: Friday, December 7, 2018 10:50:36 AM
To: Lime, Steve D (MNIT)
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] OGR GeoJSON Layers...
The following works for me with MapServer 7.0.6/GDAL 2.2.  Note it doesn't appear to pass the bbox filter to the ESRI service so this only works with small layers (otherwise it will timeout).  With newer GDAL versions 'OGRGeoJSON' will likely need to become 'ESRIJSON'.
    LAYER
        NAME 'rcoffices'
        TYPE POINT
        CONNECTIONTYPE OGR
        CONNECTION "https://maps.co.ramsey.mn.us/arcgis/rest/services/MapRamsey/MapRamseyOperationalLayersAll/MapServer/1/query?f=json&where=1=1&outFields=*&orderByFields=OBJECTID"
        DATA "OGRGeoJSON"
        PROJECTION "init=epsg:200068" END
        CLASS
            STYLE
                SYMBOL "circle"
                SIZE 10
                COLOR 255 0 0
                OUTLINECOLOR 0 0 0
            END
        END
    END
Note: epsg:200068 is setup locally as Ramsey County Coordinates:
+proj=lcc +lat_2=44.88333333333333 +lat_1=45.13333333333333 +lat_0=44.79111111111111 +lon_0=-93.38333333333334 +x_0=152400.3048 +y_0=30480.0610 +unit=sft +to_meter=0.30480060960122 +a=6378418.941 +b=6357033.310 +no_defs
On Mon, Dec 3, 2018 at 3:13 PM Lime, Steve D (MNIT) <steve.lime at state.mn.us<mailto:steve.lime at state.mn.us>> wrote:
Hi all: I’m running into an issue with GeoJSON service URLs vs local GeoJSON files. If I setup a connection like so:
  CONNECTIONTYPE OGR
  CONNECTION “http://...some arcgis server.../arcgis/rest/services...?...query string…”
and try to draw the layer it seems like it’s fetching features yet nothing is drawn. With CONFIG “CPL_DEBUG” “ON” I see an OGR message that it was able to open the URL successfully as GeoJSON . Using ogrinfo at the command line also works with the URL.
If I first save the URL response using wget and reference the local file, e.g.:
  CONNECTIONTYPE OGR
  CONNECTION “foo.json”
then the layer is drawn successfully. I know this has come up at least once before on the list but with no resolution.
This is running MapServer 6.4.5.
--Steve
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20181207/da1f2267/attachment.htm>
More information about the MapServer-users mailing list
