[mapserver-users] WFS OUTPUTFORMAT and application/json
Seth G
sethg at geographika.co.uk
Wed Dec 19 14:27:49 PST 2018
Hi list,
Has anyone run into the following issue with using "application/json" in an OUTPUTFORMAT NAME as follows?
OUTPUTFORMAT
NAME "application/json"
DRIVER "OGR/GEOJSON"
MIMETYPE "application/json; subtype=geojson"
FORMATOPTION "FORM=SIMPLE"
FORMATOPTION "STORAGE=memory"
END
Then a request such as below:
http://localhost/mapserver/?&SERVICE=WFS&REQUEST=GetFeature&VERSION=1.1.0&OUTPUTFORMAT=application/json&TYPENAME=layer&SRSNAME=EPSG:3857
Causes the following error:
msWFSGetFeature(): WFS server error. OUTPUTFORMAT 'application/json' does not have IMAGEMODE FEATURE, and is not permitted for WFS output.
Adding a IMAGEMODE FEATURE (or RGBA) doesn't resolve the issue.
I thought it may have been an issue with the slash in the NAME, but this works in other cases. Changing NAME to "geojson" also works fine, but I'm wondering why this occurs. GeoServer and TinyOWS both use "application/json" so it would be good if it worked for MapServer also.
Seth
web:http://geographika.co.uk
twitter: @geographika
