[mapserver-users] MapServer returns a blank image when requesting a square image
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Thu Jan 11 06:00:09 PST 2018
I have been using a spatialite layer as a tileindex for years without problems so definitely that is not a bug that affects all users and use cases. Try to create a zip file that contains everything that is needed for reproducing the issue. Let’s hope that you can make it with a spatialite database and two images in the tileindex.
Have you already tried to add explicit PROJECTION blocks into both LAYERs?
-Jukka Rahkonen-
Lähettäjä: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Pablo Sanfilippo
Lähetetty: 11. tammikuuta 2018 14:46
Vastaanottaja: Seth G <sethg at geographika.co.uk>
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] MapServer returns a blank image when requesting a square image
Oh, so this is a definitely a bug. Is it reported yet in the issue tracker?
On Wed, Jan 10, 2018 at 3:55 PM, Seth G <sethg at geographika.co.uk<mailto:sethg at geographika.co.uk>> wrote:
Hi Pablo,
Just to note I also ran into this issue so you are not alone!
A WMS request from OpenLayers to MapServer would be fine, but modifying the size of the image (WIDTH and HEIGHT parameters) would result in a blank image and no errors in the logs.
I never got a chance to debug further though. An error should ideally be reported somewhere rather than a blank, seemingly valid, image.
Seth
web:http://geographika.co.uk
twitter: @geographika
On Wed, Jan 10, 2018, at 6:46 PM, Pablo Sanfilippo wrote:
Hi all,
I admit this is the weirdest issue I have come across. This are the relevant parts of my MapServer configuration:
# A valid mapfile used for testing
MAP
NAME valid
STATUS ON
PROJECTION
"init=epsg:4326"
END
IMAGECOLOR 0 0 0
TRANSPARENT ON
WEB
METADATA
"wms_srs" "EPSG:4326 EPSG:3857"
END
END
LAYER
NAME "index"
STATUS ON
TYPE POLYGON
CONNECTIONTYPE POSTGIS
CONNECTION "host=x port=x dbname=x user=x password=x"
DATA "geometry from (select i.geometry, i.id<http://i.id>, '/vsis3/' || i.s3_bucket || '/' || i.s3_key as location from images_image) as index using unique id"
CLASS
STYLE
OUTLINECOLOR 0 0 0
WIDTH 1.0
COLOR 200 200 200
ANTIALIAS true
END
END
END
LAYER
NAME "images"
STATUS ON
TILEINDEX "index"
TILEITEM "location"
TYPE RASTER
PROJECTION
AUTO
END
METADATA
"wms_title" "Images"
END
END
END
The data in the PostGIS index is in EPSG:4326. The images referenced by the index are GeoTIFFs georeferenced in EPSG:4326.
A WMS request for the index layer shows the index polygons fine, whatever the SRS and image size in the request.
A WMS request for the images layer using SRS=EPSG:4326 shows the images fine, whatever the image size.
A WMS request for the images layer using SRS=EPSG:3857 will work fine as long as the requested image size's x is greater than or equal to the y. If not, it will return a blank (transparent) image. For example, a 1300x1299 image will work fine, a 1300x1300 image won't work and 1301x1300 won't work either.
Any clues?
Thanks!
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180111/a362f9ea/attachment-0001.html>
