[mapserver-users] How add a point remotelly
Andrea Peri
aperi2007 at gmail.com
Mon Jan 22 22:25:19 PST 2018
Hi Steve,
I don't knew this feature .
It work and also it is possible to add also the PROJECTION tag.
Really thx for this help.
A.
2018-01-22 17:13 GMT+01:00 Lime, Steve D (MNIT) <steve.lime at state.mn.us>:
> There are certain pieces of a mapfile that can be set via URL. Typically
> only values doing type validation in the parser. Anything else would
> require validation and some things are simply not mutable (which is where
> substitution comes in). This approach doesn't use substitution - you're
> actually passing a bit mapfile syntax. Something like this would work:
> http://localhost/cgi-bin/mapserv?map=...&map.layer['
> mypoint']=FEATURE+POINTS+100+100+END+END
> The variable name identifies the object being tweaked. The value is
> straight mapfile syntax. I'll have to look around a bit and see if I have
> any live examples on our site.
> --Steve
> *From:* mapserver-users <mapserver-users-bounces at lists.osgeo.org> on
> behalf of Yves Jacolin <yves.jacolin at camptocamp.com>
> *Sent:* Monday, January 22, 2018 3:01:51 AM
> *To:* Andrea Peri
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] How add a point remotelly
> Hello Andrea,
> You can't, only few parameters can be used for such ontime subsitution,
> see the section: http://mapserver.org/cgi/runsub.html#parameters-supported
> Regards,
> Y.
> 2018-01-21 11:41 GMT+01:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi Jukka,
> Your is a good idea.
> I try it ,
> The fragment I try is this:
> TYPE POINT
> PROJECTION
> "+init=epsg:3003"
> END
> EXTENT 1530000 4665000 1800000 4950000
> VALIDATION
> 'coordinates' '^[-a-zA-Z0-9_.\=#\'&%() ]+$'
> 'default_coordinates' '1650000 4800000'
> END
> FEATURE
> POINTS
> %coordinates% <-- line 593 of my mapfile.
> END
> END
> But unfortunally the mapserver report always the error.
> [Sun Jan 21 11:36:26 2018].660 loadFeaturePoints(): Unknown identifier.
> Parsing error near (%):(line 593)
> 2018-01-21 11:22 GMT+01:00 Rahkonen Jukka (MML) <
> jukka.rahkonen at maanmittauslaitos.fi>:
> I would try first with one variable %coordinates% for avoiding possible
> problem because of subsequent % signs.
> -Jukka Rahkonen-
> Lähettäjä: Andrea Peri <aperi2007 at gmail.com>
> Lähetetty: 21.1.2018 11:58
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] How add a point remotelly
> Hi,
> Is possible to use the runtime-substitution to add a point into a map
> layer ?
> I try this, but it do error.
> FEATURE
> POINTS
> %coord_est% %coord_north%
> The log report me: "unknow % char"
> Many thx.
> Andrea Peri
> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> Training and support manager
> Camptocamp France SAS
> Bâtiment le Dauphin - 1er étage
> 18 rue du Lac Saint André
> <https://maps.google.com/?q=18+rue+du+Lac+Saint+Andr%C3%A9&entry=gmail&source=g>
> 73382 Le Bourget-du Lac
> Tel (France) : +33 4 58 48 20 43 <+33%204%2058%2048%2020%2043>
> Tel (Switzerland) : +41 21 619 10 43 <+41%2021%20619%2010%2043>
> Mob. : +33 6 18 75 42 21 <+33%206%2018%2075%2042%2021>
> email : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180123/877dadd9/attachment.html>
