[mapserver-users] Is it possible to isolate mapserver on docker?
Antti J. Lind
anttij.lind at birdlife.fi
Fri Jul 20 04:34:58 PDT 2018
I solved this with Mapproxy (1.11.0) between Mapserver 6.2 and WMS 1.3.0
server. Mapserver still using WMS client 1.1.1.
Thank's to all, who helped me.
AJL
Humberto Cereser Ibanez kirjoitti 2018-07-04 15:47:
> "But how to use Apache's redirect with php-mapscript?"
> My Debian Jessie container has php-mapscript integrated with Apache2.
> 2018-07-01 15:54 GMT-03:00 Rahkonen Jukka (MML)
> <jukka.rahkonen at maanmittauslaitos.fi>:
>> Hi,
>> As a workaround for your problem with remote WMS that only supports
>> WMS 1.3.0 it might be possible to use MapCache in between. It should
>> be able to read WMS 1.3.0. It can also read WMTS if your service
>> provider has WMTS available.
>> -Jukka Rahkonen-
>> ________________________________________
>> Lähettäjä: mapserver-users
>> <mapserver-users-bounces at lists.osgeo.org> käyttäjän
>> puolestaAntti J. Lind <anttij.lind at birdlife.fi>
>> Lähetetty: 1. heinäkuuta 2018 20:38
>> Vastaanottaja: mapserver-users at lists.osgeo.org
>> Aihe: Re: [mapserver-users] Is it possible to isolate mapserver on
>> docker?
>> Hi and thank's,
>> AJL
>> Humberto Cereser Ibanez kirjoitti 2018-06-30 19:14:
>>> ...but then you would proxy that out to your external http server.
>>> I'm using Apache2 Redirect:
>>> Redirect /example http://172.17.0.3/example
>>> on vhost who is also a container in the same host.
>>> 172.17.0.3 is the ip of the container with Apache2 and Mapserver
>>> 2018-06-30 11:32 GMT-03:00 Michael Smith
>>> <michael.smith.erdc at gmail.com>:
>>>> You can certainly run mapserver via cgi standalone on docker but
>> if
>>>> you want to do php mapscript, you’d need mapserver compiled
>> with
>>>> php mapscript in the docker container. If you do that, you’d
>>>> probably need a http server inside the container but then you
>> would
>>>> Michael Smith
>>>>> On Jun 30, 2018, at 9:59 AM, Antti J. Lind
>>>> <anttij.lind at birdlife.fi> wrote:
>>>>> Hello list,
>>>>> We are currently using php-mapserver-apache on centos7.
>>>>> Now there is one wms-server, which is using wms server version
>>>> 1.3.0 and our mapservers client does not.
>>>>> It seems to be quite big change to update our current version
>> 6.2
>>>> to 7.2 beta and run it on same host as php-scripts and apache.
>>>>> It there some way to isolate mapserver on docker or run it on
>>>> another host without http-server?
>>>>> On docker hub there is only images, which are including
>>>> http-server with mapserver.
>>>>> Antti J. Lind
>>>>> BirdLife Finland
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users [1] [1]
>>> Links:
>>> [1] https://lists.osgeo.org/mailman/listinfo/mapserver-users [1]
> Links:
