[mapserver-users] Is it possible to isolate mapserver on docker?
Humberto Cereser Ibanez humberto at pastoraldacrianca.org.br
Sat Jun 30 09:14:03 PDT 2018
...but then you would proxy that out to your external http server.
I'm using Apache2 Redirect:
Redirect /example http://172.17.0.3/example
on vhost who is also a container in the same host.
172.17.0.3 is the ip of the container with Apache2 and Mapserver
2018-06-30 11:32 GMT-03:00 Michael Smith <michael.smith.erdc at gmail.com>:
> You can certainly run mapserver via cgi standalone on docker but if you
> want to do php mapscript, you’d need mapserver compiled with php mapscript
> in the docker container. If you do that, you’d probably need a http server
> inside the container but then you would proxy that out to your external
> http server.
> Michael Smith
> > On Jun 30, 2018, at 9:59 AM, Antti J. Lind <anttij.lind at birdlife.fi>
> wrote:
> > Hello list,
> > We are currently using php-mapserver-apache on centos7.
> > Now there is one wms-server, which is using wms server version 1.3.0 and
> our mapservers client does not.
> > It seems to be quite big change to update our current version 6.2 to 7.2
> beta and run it on same host as php-scripts and apache.
> > It there some way to isolate mapserver on docker or run it on another
> host without http-server?
> > On docker hub there is only images, which are including http-server with
> mapserver.
> > Antti J. Lind
> > BirdLife Finland
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180630/948d4a8e/attachment.htm>
More information about the MapServer-users mailing list
