[mapserver-users] How return a different result for different IPs
Kralidis, Tom (EC)
tom.kralidis at canada.ca
Tue Mar 6 07:18:01 PST 2018
Hi Andrea:
You could serve your WMS via MapScript which could intercept the
request and adjust the mapfile object in memory before executing the response.
We've done this with Python MapScript in implementing the WMS Best Practice
for Time/Elevation, but there's no reason why the same approach couldn't work
with processing IPs.
Hope this helps.
..Tom
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Andrea Peri
Sent: 06 March 2018 10:12
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] How return a different result for different IPs
I need to implement a wms mapserver service where from a layer.
when done a GetFeatureInfo the system return a different geometry for differents IP address.
More explicitly. It should return the exact geometry for some explicited IP address and return instead the Boundign Box for every other IP address.
Actually the only one solution I know is implement a front-end filter that redirect to one wms service where the dataset is with bbox geometry only for some IP and redirect to another wms system where there s a dataset with exact geometries for specific IP addresses.
But of course I like if there is a choice of solution inside the mapserver world.
Any help is welcome.Thx,
Andrea
Andrea Peri
qwerty àèìòù
