[mapserver-users] What is the best way to generate WMS?
Vladimir
fl_v at inbox.ru
Fri Sep 21 04:49:44 PDT 2018
Thank you very much, Sven.
Is it right to use FastCGI for less resource consumption?
What language of MapScript is more suitable the best performance?
Regards.
>Hi Vladimir,
>the fastest way is probably the CGI variant. You write your mapfiles and deliver the data via mapserv and the corresponding parameters.
>In the case of PHP you have to build a wrapper, which is no problem. If your server runs under windows, this is the better variant, because many firewalls close when you call mapserv.exe.
>When it comes to custom programming, the php (or python or C# or Java) variant has more influence.
>Greetings
>Sven
>Von: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Vladimir
>Gesendet: Freitag, 21. September 2018 09:51
>An: mapserver-users
>Betreff: [mapserver-users] What is the best way to generate WMS?
>Hi list,
>There are several tables with a lot of objects in PostGis database.
>Fields of the tables contain styles(color, width etc)
>The goal is fast getting a single image(WMS) on client .
>I am aware about two ways to do it:
>mapserv as FactCGI and some kind of MapScript(PHP in my case)
>What is the best for performance?
>Is there more productive way?
>Regards.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180921/8d92b20b/attachment.html>
