[mapserver-users] mapserver 7.4 beta phpng build error
Richard Greenwood
richard.greenwood at gmail.com
Wed Apr 3 19:41:38 PDT 2019
Seth,
I understand that there are two php versions and the native one builds fine
for me. But the swig one (phpng) does not. I installed swig 3.0.12. My
build fails with error:
/rwg/src/mapserver-branch-7-4/build/mapscript/phpng/mapscriptPHP7_wrap.c:
No such file or directory
I can't find the file mapscriptPHP7_wrap.c
Thanks,
Rich
On Wed, Apr 3, 2019 at 4:34 PM Seth G <sethg at geographika.co.uk> wrote:
> There are now 2 PHP MapScripts. See
> https://mapserver.org/development/rfc/ms-rfc-117.html for details.
> The "native" one has been updated to work with PHP7 in the MapServer 7.4
> release, and also a new SWIG based PHP MapScript is now available. The
> first does not require SWIG, the latter does.
> These can be build by setting the following 2 flags:
> WITH_PHP "Enable PHP mapscript support" OFF
> WITH_PHPNG "Enable PHPNG (SWIG) mapscript support" OFF
> web:http://geographika.co.uk
> twitter: @geographika
> On Thu, Apr 4, 2019, at 12:06 AM, Richard Greenwood wrote:
> On Wed, Apr 3, 2019 at 10:39 AM Seth G <sethg at geographika.co.uk> wrote:
> Hi Richard,
> If you had previous errors it may be best to delete the whole
> /rwg/src/mapserver/build/ and start the build from scratch again.
> I did do that.
> Also to note is PHP 7 support was only added in SWIG-3.0.11. I'm trying to
> get this set up on Travis and can do so with the following command:
> sudo wget http://prdownloads.sourceforge.net/swig/swig-3.0.12.tar.gz
> tar xf swig-3.0.12.tar.gz
> cd swig-3.0.12 && ./configure --prefix=/usr && make && sudo make install
> swig -version
> Not sure I'm following you. Do I need to have swig installed? I don't.
> I've run into further errors but mapscriptPHP7_wrap.c is created at least.
> Again, not sure I'm following you. Is mapscriptPHP7_wrap.c supposed to be
> in the source files that I download or git clone, or is it created in the
> build process?
> Seth
> On Wed, Apr 3, 2019, at 4:11 AM, Richard Greenwood wrote:
> I get the following error:
> Building C object
> mapscript/phpng/CMakeFiles/php_mapscriptng.dir/mapscriptPHP7_wrap.c.o
> cc: error: /rwg/src/mapserver/build/mapscript/phpng/mapscriptPHP7_wrap.c:
> cc: fatal error: no input files
> If i'm reading the error message correctly it's not finding
> "mapscriptPHP7_wrap.c". I don't have "mapscriptPHP7_wrap.c". I tried the
> file at
> https://github.com/mapserver/mapserver/releases/tag/rel-7-4-0-beta1
> as well as git cloning.
> I'm not well versed with this stuff so apologizes in advanced if I'm
> missing the obvious.
> Rich
> Richard W. Greenwood, PLS
> www.greenwoodmap.com
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190403/031cc100/attachment.htm>
More information about the MapServer-users
