[mapserver-users] CONNECTIONTYPE OGR is not working after upgrade to mapserver 7.2.2 from 6.4.1
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Apr 4 06:43:05 PDT 2019
To access a remote WFS service, be sure to set CONNECTIONTYPE WFS in
your layer, as in the example at
https://mapserver.org/ogc/wfs_client.html#example-wfs-layer
I guess I am not understanding your question properly.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2019-04-04 5:23 AM, Lars Fricke wrote:
> Hello,
> First of all: thank you for your time!
> I have been running into a strange problem lately. We have a server
> running mapserver 6.4.1 (Debian GNU/Linux 8.0 jessie) that is accessing
> a remote WFS as client without any problems.
> We have another (local development) server that has been upgraded to
> mapserver 7.2.2 (Ubuntu 18.04 bionic) and that can no longer access the
> WFS. Everything was fine with the older versions on that server, too
> (not certain if the mapserver upgrade happened at the same time as the
> Ubuntu upgrade).
> The error received is:
> msOGRFileOpen(): OGR error. GetLayer(LAYER_NAME) failed for OGR
> connection. Check logs.
> The logs are not giving me any further information. Even I put debug
> level to 5 already. Also apache log is not giving me any clue, there is
> no error. Other layers on the same server open fine, as long a they do
> not need OGR. So I assume it is not a connection issue.
> ogrinfo however can access the external WFS fine from the terminal.
> Configuration:
> Mapserver 7.2.2
> gdal-bin 2.4.0+dfsg-1~bionic0 (from UbuntuGIS - unstable repo)
> Ubuntu 18.04 bionic
> I also have NextGIS repository activated but it does not seem that
> gdal/ogr is installed from there.
> mapserv -v shows:
> MapServer version 7.2.2 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS
> SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> I have also checkt $Path:
> /home/lars/bin /usr/local/sbin /usr/local/bin /usr/sbin /usr/bin /sbin
> /bin /usr/games /usr/local/games /snap/bin
> I am not certain, if that is correct but ogr seems to be in /usr/bin so
> I'd expect it's available for mapserver, too.
> gdalinfo --formats does not show WFS, if that is the problem, where do I
> get gdal with WFS enabled?
> The mapfile is the same on both servers (relevant code only):
> LAYER
> NAME "TEST"
> TYPE Point
> UNITS METERS
> CONNECTION "http://XXX&VERSION=1.1.0&SERVICE=WFS"
> CONNECTIONTYPE OGR
> STATUS ON
> DEBUG ON
> DEBUG 5
> DATA "LAYER_NAME"
> METADATA
> "wfs_version" "1.1.0"
> "wfs_title" "TEST"
> "wfs_connectiontimeout" "300"
> "wfs_typename" "Test_int"
> "wfs_maxfeatures" "500"
> "gml_include_items" "all"
> #"wfs_srs" "epsg:25832"
> "gml_featureid" "ID"
> "wfs_enable_request" "*"
> END # METADATA
> PROJECTION
> "init=epsg:25832"
> END # PROJECTION
> CLASS
> NAME "Testlayer"
> STYLE
> COLOR 190 87 66
> OUTLINECOLOR 255 0 0
> SIZE 4
> SYMBOL "circle_filled"
> END # STYLE
> END # CLASS
> END # LAYER
> I'd really appreciate any help where to look further. I have been at
> this for a few days already. I tried to give as much information as
> possible, if something important is missing, please let me know.
> Thanks again for your time!
> Best
> Lars
> SkenData GmbH
