[mapserver-users] Mapcache WMTS - imagery is offset in ArcGIS when using WMTS services.
Lime, Steve D (MNIT)
steve.lime at state.mn.us
Fri Apr 12 15:00:19 PDT 2019
The resolution doesn't matter. That just impacts scale computations internally so when layers/classes are on/off and how symbol/font scaling is done.
I just tried our Compass MapCache/WTMS service overlaid with a shapefile in UTM projected appropriately and they line up perfectly in ArcGIS 10.6. You can try it too with your data since you're in MN (http://maps1.dnr.state.mn.us/mapcache/wmts/1.0.0/WMTSCapabilities.xml). Does it behave any differently for you?
--Steve
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mark Volz
Sent: Friday, April 12, 2019 12:08 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Mapcache WMTS - imagery is offset in ArcGIS when using WMTS services.
Hello,
I noticed that WMTS services are extremely fast when using Mapcache to serve tiles to ArcGIS clients. However, the imagery appears to be shifted down significantly from the actual location. I did notice that Mapserver and Mapcache use a 72 DPI while ArcGIS is using a 90.714 DPI. In addition the image is the correct width and height. In addition, when I use WMS the imagery appears in the correct location, however it is not as fast as WMTS.
Please let me know if there is a way to get ArcGIS to place imagery in the correct location when using WMTS and Mapcache.
Thanks
Sincerely,
Mark Volz, GISP
Lyon County GIS Coordinator
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190412/bea86f0b/attachment.html>
