[mapserver-users] The GetFeature WFS Request fail if the layer is empty
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Tue Aug 13 00:00:09 PDT 2019
What kind of source dataset do you have, and do you mean that for example a PostGIS table exists but there are no rows in the table?
-Jukka Rahkonen-
Lähettäjä: mapserver-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Andrea Peri
Lähetetty: maanantai 12. elokuuta 2019 14.30
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] The GetFeature WFS Request fail if the layer is empty
I' notice that the GetFeature WFS request of a mapserver (i'm work using master) return an error if the dataset (and so the layer) is empty.
I test using version 1.0.0, 1.1.1 and 2.00.
On 2.0.0 the result is:
http status 400
The request sent by the client was syntactically incorrect.
On 1.1.0 and 1.0.0 the result is an xml exception with:
msWFSGetFeature(): WFS server error. ms_error->code not found
I Guess it should return not an exception or error, but instead an empty GML or an Empty Shapefile and so on...
Before to build a test service of this issue, I like to know if this instead is a confirmed specific characteristic of a wfs service.
Thx,
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190813/ed71c427/attachment.htm>
More information about the MapServer-users mailing list
