[mapserver-users] Projection help
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Aug 1 03:19:49 PDT 2019
Next time you can prevent this grief by following the "Important Points"
in the projections doc, when dealing with input & output projections,
and extents:
https://mapserver.org/mapfile/projection.html#important-notes I often
use these concepts for debugging issues like this.
-jeff
Thank you for using MS4W.
"MS4W: open doors as well as windows"
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2019-07-31 11:01 PM, Ian Walberg wrote:
> Steve,
> Actually that does work.
> Thanks
> Ian
> *From:* Ian Walberg
> *Sent:* Wednesday, July 31, 2019 7:00 PM
> *To:* 'Lime, Steve D (MNIT)' <steve.lime at state.mn.us>;
> mapserver-users at lists.osgeo.org
> *Subject:* RE: Projection help
> Steve,
> Good point, I did have the extent in meters but that did not work.
> Should these work?
> EXTENT -20026376 -20048966 20026376 20048966
> Thanks
> Ian
> *From:* Lime, Steve D (MNIT) <steve.lime at state.mn.us
> <mailto:steve.lime at state.mn.us>>
> *Sent:* Wednesday, July 31, 2019 6:38 PM
> *To:* Ian Walberg <ian.walberg at airborne.aero
> <mailto:ian.walberg at airborne.aero>>; mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> *Subject:* Re: Projection help
> How are you setting an extent? The default extent you’re defining is in
> lat/lon.
> *From:*Ian Walberg <ian.walberg at airborne.aero
> *Sent:* Wednesday, July 31, 2019 5:34:05 PM
> *To:* Lime, Steve D (MNIT) <steve.lime at state.mn.us
> <mailto:steve.lime at state.mn.us>>; mapserver-users at lists.osgeo.org
> <mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>>
> *This message may be from an external email source.*
> Do not select links or open attachments unless verified. Report all
> suspicious emails to Minnesota IT Services Security Operations Center.
> Steve,
> The map file below draws a non Mercator projection and if the epsg:4326
> line is uncommented then the map is blank.
> This is on a windows machine using Mapserver 7.0.7 from MS4W 3.2.6.
> Any ideas?
> Thanks
> Ian
> MAP
> NAME global_map
> STATUS ON
> SIZE 1024 600
> EXTENT -180 -90 180 90
> LAYER
> NAME "Earth_Vector"
> STATUS DEFAULT
> TYPE LINE
> DEBUG 3
> PROJECTION
> # "init=epsg:4326"
> END
> DATA "../shp/land/ne_110m_land.shp"
> CLASS
> STYLE
> ANTIALIAS TRUE
> COLOR 0 255 0
> WIDTH 1
> END
> END
> END
> PROJECTION
> "init=epsg:3857"
> END
> END #MAP END
> *Sent:* Wednesday, July 31, 2019 3:22 PM
> Should be straight forward. In the natural earth layers you’d have:
> PROJECTION
> "init=epsg:4326" # geographic
> END
> and at the MAP level you’d have:
> PROJECTION
> "init=epsg:3857" # web mercator
> END
> --Steve
> *From:* mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org]
> *On Behalf Of *Ian Walberg
> *Sent:* Wednesday, July 31, 2019 4:56 PM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Projection help
> Hello,
> We have used different projections previously but cannot get them to
> work at the moment.
> All the examples we can find online look ok but do not make any
> difference to the generated map.
> A way of projecting the Natural Earth vector country outlines as
> Mercator would be a perfect example.
> Adding CONFIG "PROJ_DEBUG" "ON" does not appear to generate any output.
> Thanks
> Ian
