[mapserver-users] ows_denied_ip_list is working ?
Andrea Peri
aperi2007 at gmail.com
Mon Aug 12 03:56:14 PDT 2019
Hi Steve,
thx for your test.
I do more test to try to understand better what I'm wrong.
Just to do a better with an more large IP range.
Is possibile to use the IP/CIDR sintax to describe the IP range or need to
list all the IP denied ?
A.
Thx,
Il giorno mer 31 lug 2019 alle ore 23:50 Lime, Steve D (MNIT) <
steve.lime at state.mn.us> ha scritto:
> Hi Andrea: I just tested with MapServer 6.4 and 7.4 and it works as
> expected, at least with WMS GetMap requests. My process was:
> 1. Make a WMS request and check the logs to confirm the IP I was
> showing up as.
> 2. Edit the mapfile and add “ows_denied_ip_list” “my IP” to the WEB
> METADATA section.
> 3. Perform the same WMS request in the browser – result was a WMS
> exception.
> 4. Edit the mapfile and change the ip slightly so it shouldn’t
> match but leaving the directive in place.
> 5. Perform the same WMS request in the browser – result was a PNG
> image.
> I did tried multiple IPs in the list, with and without my IP and
> everything worked as expected. I did not try using an external file. I did
> notice with my IP in the list a GetMap request was blocked, a
> GetCapabilities request was not. I didn’t try a GetFeature… request.
> Makes me wonder if you have the right IP for your test setup?
> --Steve
> *From:* Andrea Peri [mailto:aperi2007 at gmail.com]
> *Sent:* Tuesday, July 30, 2019 2:30 PM
> *To:* Lime, Steve D (MNIT) <steve.lime at state.mn.us>;
> mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] ows_denied_ip_list is working ?
> Hi,
> I was using a compiled version from a recent clone of master .
> I try to apply ot to WEB-> METADATA section section using this kind of
> values:
> I try to use a list of IP directly listed using a space as separator
> "ows_denied_ip_list" "xxx.xxx.xxx.xxx yyy.yyy.yyy.yyy
> zzz.zzz.zzz.zzz"
> or using a file where there is the same list one IP for line
> "ows_denied_ip_list" "file:/path-to-file/file-with-ip-list.txt"
> The values listed are the possibly values of our proxy.
> So I guess setting them as denied IP mapserver should refuse to give a map
> to every client wms using them.
> Instead the map are still showed.
> I'm using QGIS as wms client to test it.
> A.
> Il mar 30 lug 2019, 04:21 Lime, Steve D (MNIT) <steve.lime at state.mn.us>
> ha scritto:
> I will test and reply back. What specific version, config and tests did
> you try on your end?
> *From:* mapserver-users <mapserver-users-bounces at lists.osgeo.org> on
> behalf of Andrea Peri <aperi2007 at gmail.com>
> *Sent:* Saturday, July 27, 2019 9:02:07 AM
> *To:* mapserver-users at lists.osgeo.org <mapserver-users at lists.osgeo.org>
> *Subject:* [mapserver-users] ows_denied_ip_list is working ?
> Hi,
> I see my version of mapserver don't work the ows_denied_ip_list.
> I see ths other mex:
> http://osgeo-org.1560.x6.nabble.com/ows-allowed-ip-list-ows-denied-ip-list-not-working-td5202667.html
> <https://gcc01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fosgeo-org.1560.x6.nabble.com%2Fows-allowed-ip-list-ows-denied-ip-list-not-working-td5202667.html&data=02%7C01%7CSteve.Lime%40state.mn.us%7Ca2bef76fd62f471db1e608d715245908%7Ceb14b04624c445198f26b89c2159828c%7C0%7C0%7C637001118169695729&sdata=PWJxX4BJMhOodJ7FadppgR%2F3XAk9lLW%2FHJadeWehSRQ%3D&reserved=0>
> I try all the same option but nothing is work.
> So I guess that instead that the ows_denied_ip_list was dismissed.
> Is this confirmed ?
> Thx.
> A.
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190812/e3e16907/attachment.html>
