[mapserver-users] Error compiling mapserver
Andrea Peri
aperi2007 at gmail.com
Wed Aug 21 01:01:21 PDT 2019
I have update to last debian my pc and when try to recompile the mapserver
from the last trunk code,
I have this error:
[ 79%] Building CXX object
CMakeFiles/mapserver.dir/mapscript/v8/v8_mapscript.cpp.o
[ 79%] Linking CXX shared library libmapserver.so
[ 79%] Built target mapserver
Scanning dependencies of target shptreetst
[ 80%] Building C object CMakeFiles/shptreetst.dir/shptreetst.c.o
[ 81%] Linking C executable shptreetst
/usr/bin/ld: warning: libjpeg.so.8, needed by /usr/local/lib/libgdal.so,
may conflict with libjpeg.so.62
//usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0: undefined reference to
`hb_font_funcs_set_nominal_glyph_func'
`hb_font_set_variations'
`hb_variation_from_string'
`hb_buffer_set_cluster_level'
`hb_font_funcs_set_variation_glyph_func'
collect2: error: ld returned 1 exit status
CMakeFiles/shptreetst.dir/build.make:112: recipe for target 'shptreetst'
failed
make[2]: *** [shptreetst] Error 1
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/shptreetst.dir/all'
failed
make[1]: *** [CMakeFiles/shptreetst.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
I don't understand if the issue is in the libjpeg.so.8 version
or instead an issue due to a deprecation in the libpangoft2-1.0 of some
references.
Any help is welcome.
Thx.
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190821/3a0a6b7e/attachment.html>
