[mapserver-users] MS4W version 4.0.1 released
Jan Hartmann
j.l.h.hartmann at uva.nl
Mon Aug 26 03:00:11 PDT 2019
Just curious, how can I use the RT Topology library within Mapserver?
Jan
On 8/26/2019 11:43 AM, Jeff McKenna wrote:
> Hello everyone,
> MS4W 4.0.1 is now available, which contains many security updates, as
> well as a few important changes. Get it now at https://ms4w.com
> Please see MS4W's HISTORY.txt for all of the changes, but here are
> some of the highlights:
> - upgraded MapServer and MapScript (CSharp, Java, Python, PHP) to
> today’s 7.6.0-dev (also due to potential XSS vulnerability)
> - disabled Pixman support in MapServer build, as it prevents Opacity
> (trac ticket 218)
> - upgraded PHP to 7.2.21 (trac ticket 213)
> - upgraded GDAL to 2.4.2 (trac ticket 195)
> - upgraded Apache HTTP Server to 2.4.41 (trac ticket 206)
> - upgraded MapCache to today’s 1.9dev (trac ticket 222)
> - upgraded OpenSSL support to 1.1.1c (trac ticket 191)
> - upgraded cURL support to 7.65.1
> - upgraded NetCDF support to 4.7.0 (trac ticket 193)
> - upgraded GEOS support to 3.7.2 trac ticket 214)
> - rebuilt RT Topology Library
> - upgraded libxml2 support to 2.9.9
> - upgraded Freetype support to 2.10.1
> - upgraded PostgreSQL support to 11.4 with SSL enabled (ticket 196)
> - upgraded HDF5 support to 1.10.5
> - upgraded SQLite support to 3.28.0
> - rebuilt SpatiaLite support
> - rebuilt spatialite-tools
> - upgraded libPNG support to 1.6.37 (trac ticket 221) due to potential
> vulnerability
> - upgraded Pixman support to 0.38.4
> - upgraded Cairo support to 1.16.0
> - rebuilt Poppler support
> - upgraded HarfBuzz support to 2.5.3
> - rebuilt libSVG support
> - rebuilt libSVG-Cairo support
> - updated cURL certificates bundle
> - rebuilt mod_fcgid
> - rebuilt Apache H264 Streaming Module
> - upgraded osm2pgsql commandline utility to today’s git master
> - rebuilt php_ogr extension
> - upgraded Shapelib support to 1.5.0 (trac ticket 192)
> - rebuilt shp2tile utility
> - set “sys_temp_dir” in php.ini (trac ticket 204)
> - upgraded APR support to 1.7.0
> - added /Python/Scripts/ to PATH in setenv.bat (trac ticket 225)
> - copied GDAL’s python module into /Apache/cgi-bin/ (trac ticket 223)
> - and many more...
> When installing, it is very important that (if you are using the .zip)
> your server must have the C++ Redistributable installed on it
> beforehand: execute the local file /ms4w/tmp/vcredist_x86.exe
> (alternatively if you use MS4W's setup.exe installer this is done
> automatically)
> As always please provide your requests for enhancements and issues
> through the MS4W tracker (so the feedback is not lost or forgotten):
> https://ms4w.com/trac/ You can also contact me directly for support.
> Thank you all for sharing your spatial information with MS4W !!
> "MS4W: open doors and as well as windows"
> -jeff
