[mapserver-users] styling based on attribute for MapServer derived MVTiles
Lime, Steve D (MNIT)
steve.lime at state.mn.us
Tue Feb 5 12:15:23 PST 2019
I believe the default WxS behavior is to expose no attributes. You need to be explicit and I don't see the gml_include_items metadata property in the mapfile for the layer allcountries. You'd need something like:
"gml_include_items" "mapcolor7"
Added to the allcountries layer. The mvt-demo does this for most layers...
--Steve
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of karsten
Sent: Monday, February 04, 2019 4:33 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] styling based on attribute for MapServer derived MVTiles
Dear All,
I was working on the configuration of MapServer generated MVT tiles for a demo country world map and had success with MS v 7.2 outputting tiles in MVT format ( all thanks to https://github.com/sdlime/mvt-demo<https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fsdlime%2Fmvt-demo&data=02%7C01%7Csteve.lime%40state.mn.us%7C98620848f458446d1e2608d68af0c31b%7Ceb14b04624c445198f26b89c2159828c%7C0%7C1%7C636849164006408831&sdata=QYGGj%2FDN87pFfCjzP0CHZBoomTp38zRhupXy2%2BjGyi8%3D&reserved=0> ).
I am trying to work on the client side style for my demo map (using mapbox-gl.js) and defined them in a similar way as JSON as in Steve's mvt-demo above. The whole thing is later intended to be used in a benchmark for MapServer MVT rendering speed versus T-Rex ( see http://blog.sourcepole.ch/2018/09/06/the-tale-of-a-vector-tile-benchmark/<https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fblog.sourcepole.ch%2F2018%2F09%2F06%2Fthe-tale-of-a-vector-tile-benchmark%2F&data=02%7C01%7Csteve.lime%40state.mn.us%7C98620848f458446d1e2608d68af0c31b%7Ceb14b04624c445198f26b89c2159828c%7C0%7C1%7C636849164006418845&sdata=F7kfmr8XBKaraOdKcglqApDt%2BSuWAHSJ7x%2BTI6GJCHw%3D&reserved=0> ) .
For now I am struggling with specifying the correct style syntax for the client side and it seem that I missing something as I was not yet able to successfully use attribute properties to render Countries as different colors based on an attribute field of my PostGIS source.
Below is the configuration of my 'allcountries' layer. The mapcolor7 filed is an integer field (in the input PostGIS source) but my set-up fails to output multiple colors , instead I am getting all default black for the country fill color. A second layer where I specified only Italy as one Country 'country-italy' to show up renders fine - see https://github.com/karstenv/mvt-benchmark/blob/master/MapServer/countries_mvt.png<https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fkarstenv%2Fmvt-benchmark%2Fblob%2Fmaster%2FMapServer%2Fcountries_mvt.png&data=02%7C01%7Csteve.lime%40state.mn.us%7C98620848f458446d1e2608d68af0c31b%7Ceb14b04624c445198f26b89c2159828c%7C0%7C1%7C636849164006428858&sdata=1XeorZJ2Tf%2FeYSD2Cs5N3JcvszoU1nplrtrqDMc%2BqXw%3D&reserved=0>
My complete style JSON is at https://github.com/karstenv/mvt-benchmark/blob/master/MapServer/ms_ne_simple.json<https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fkarstenv%2Fmvt-benchmark%2Fblob%2Fmaster%2FMapServer%2Fms_ne_simple.json&data=02%7C01%7Csteve.lime%40state.mn.us%7C98620848f458446d1e2608d68af0c31b%7Ceb14b04624c445198f26b89c2159828c%7C0%7C1%7C636849164006438854&sdata=O4%2F91Tdg2%2BCCiHCJr1hvWqc9f4K%2B%2FBa%2FJAW4vBHbY58%3D&reserved=0>
and the corresponding map file is here https://github.com/karstenv/mvt-benchmark/blob/master/MapServer/ne.map<https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fkarstenv%2Fmvt-benchmark%2Fblob%2Fmaster%2FMapServer%2Fne.map&data=02%7C01%7Csteve.lime%40state.mn.us%7C98620848f458446d1e2608d68af0c31b%7Ceb14b04624c445198f26b89c2159828c%7C0%7C1%7C636849164006448867&sdata=CJawtbiFdYOcG2fa1PxgWHHfqV1Hz18tSz71k4N59ws%3D&reserved=0>
Would anyone know what I need to change in order to render the countries with different colors according to the 'mapcolor7' attribute ?
To me it seems that somehow the attribute is not available to the renderer even though in the MapServer map file I am selecting all fields in the sub-query ...
Thanks
Karsten
"id": "country-fill",
"type": "fill",
"source": "compass",
"source-layer": "allcountries",
"paint": {
"fill-color": {
"property": "mapcolor7",
"stops": [
[1, "#fdaf6b"],
[2, "#fdc663"],
[3, "#fae364"],
[4, "#d3e46f"],
[5, "#aadb78"],
[6, "#a3cec5"],
[7, "#ceb5cf"]
"id": "country-italy",
"type": "fill",
"source-layer": "italy",
"paint": {
"fill-color": "#fdc663"
Karsten Vennemann
Terra GIS
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190205/6a46619d/attachment.html>
