[mapserver-users] mapcache seed slow
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Fri Feb 22 07:03:20 PST 2019
Stupid question, but do you know how fast your WMS service is? How many GetMap requests/sec it can serve with the metatile size that you are seeding with? Have you some evidence that WMS is running idle while MapCache is busy with cutting the tiles and filling the cache?
-Jukka Rahkonen-
Lähettäjä: mapserver-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Sebastiano Laini
Lähetetty: perjantai 22. helmikuuta 2019 13.35
Vastaanottaja: 'mapserver-users at lists.osgeo.org' <mapserver-users at lists.osgeo.org>
Aihe: [mapserver-users] mapcache seed slow
Hi all,
I'm trying to seed the whole UK at all zoom lv with these resolutions
<resolutions>280 140 70 28 14 7 6.16 2.8 1.4 0.7</resolutions>
But after 13 days it arrives at the 5th level where before I kill the process it seed just 900MB on that level.
This is my script
su -s /bin/sh apache -c "/usr/local/bin/mapcache_seed -c /usr/local/src/mapcache-1.6.1/build/mapcache.xml -t bccache -g bcgrid -z 5,6 -n 400" 2>&1> /var/www/vhosts/$SITE/scripts/cache_log.txt
I know that in the documentation say that -n should be less or max the number of cpu in the server but is really slow if I put 2, so I tried with 100 and after 13 days that was the result so now I'm trying 400
Is there something else I can use to speed up the seed? I'm using the SQlite cache method
Should I use the -p (| -nprocesses: number of parallel processes that should be used to request tiles from the WMS source) Instead of the -n parameter?
Sebastiano Laini
Web Developer
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190222/a6719324/attachment.html>
