[mapserver-users] csharp_mapscript dotnet core on Linux
ruigis
ruigis at protonmail.com
Sun Jan 13 12:46:22 PST 2019
I finally made it. After editing a couple of swig templates I managed to
compile the mapscript_csharp and use it from dotnet core 2.2
<http://osgeo-org.1560.x6.nabble.com/file/t384371/Screenshot_at_2019-01-13_20-38-25.png>
Here is the commit with a bunch of changes:
https://github.com/3x0dv5/mapserver/commit/61164981367899632006918b757c6a553cad1f02
Now the thing is that probably most of what I did was probably not needed,
but maybe it is actually useful for the project. So if someone could take a
quick look and see what could be used.
My process to compile:
1. git clone of master
2. mkdir build
3. cd build
4. cmake -DCMAKE_INSTALL_PREFIX=/opt \
-DCMAKE_PREFIX_PATH=/usr/lib/x86_64-linux-gnu:/usr/share/postgresql/10:/usr/local:/opt
-DWITH_CLIENT_WFS=ON \
-DWITH_CLIENT_WMS=ON \
-DWITH_CURL=ON \
-DWITH_SOS=ON \
-DWITH_PHP=OFF \
-DWITH_PERL=OFF \
-DWITH_RUBY=OFF \
-DWITH_JAVA=OFF \
-DWITH_CSHARP=ON \
-DWITH_PYTHON=OFF \
-DWITH_SVGCAIRO=OFF \
-DWITH_ORACLESPATIAL=OFF \
-DWITH_MSSQL2008=OFF \
../ >../configure.out.txt
5. at this point there is still one small issue with the code generated by
SWIG:
the file: build/mapscript/csharp/mapscriptPINVOKE.cs
has the following duplicated, I needed to delete one
static mapscriptPINVOKE() {
6. make all
7. open Jetbrains Rider and create a sample console project and add
reference to the mapscript_csharp.dll also add the PATH where mapscript.so
is or copy it to the /bin/Debug/netcoreapp2.2/
My sample output:
proj1$ dotnet run
MapServer version MapServer version 7.3-dev OUTPUT=PNG OUTPUT=JPEG
SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV
SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
SUPPORTS=GEOS SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
Running on .NETCoreApp,Version=v2.2
Linux kernel: Unix 4.20.0.42000
Sent from: http://osgeo-org.1560.x6.nabble.com/Mapserver-User-f4226646.html
