[mapserver-users] PHP Mapscript styleObj implementation broken?
Seth G
sethg at geographika.co.uk
Fri Jan 25 10:18:25 PST 2019
Hi Nicol,
Not sure if this helps but in the Python MapScript bindings the API changed at some point, and now uses:
symbol.pattern = [0, 1]
https://github.com/mapserver/mapserver/blob/418e15cda5109e3a47c6691567e3e3e62e964187/mapscript/python/tests/cases/symbol_test.py#L135
This however is specific to Python:
https://github.com/mapserver/mapserver/blob/418e15cda5109e3a47c6691567e3e3e62e964187/mapscript/python/pyextend.i#L231
I'm guessing you are using PHP MapScript rather than the new SWIG generated SWIG MapScript bindings?
Seth
web:http://geographika.co.uk
twitter: @geographika
On Fri, Jan 25, 2019, at 6:17 PM, Nicol Hermann wrote:
> Hello,
> after looking closer into the source code I was able to resolve the
> issue of setting the 'linecap' property. The property expects
> constants. It works if you are specifying one of them:
> MS_CJC_NONE (0)
> MS_CJC_BEVEL (1)
> MS_CJC_BUTT (2)
> MS_CJC_MITER (3)
> MS_CJC_ROUND (4)
> MS_CJC_SQUARE (5)
> MS_CJC_TRIANGLE (6)
> MS_CJC_DEFAULT_JOIN_MAXSIZE
> However I am still not able to figure out what's going on with the
> setPattern() method.
> Any hints are greatly appreciated.
> Thanks
> Nicol
> Am Donnerstag, den 24.01.2019, 19:21 +0100 schrieb Nicol Hermann:
> > Hello,
> > I have huge difficulties to use the styleObj in PHP MapScript
> > (Mapserver 7.3-dev, PHP 7.1).
> > I am struggling with the setPattern() method and the linecap
> > property.
> > If I am using
> > $styleObj-> setPattern( array( 8.0, 12.0) );
> > this gets translated to the following MapFile syntax
> > PATTERN
> > 4620693217682128896.00 4622945017495814144.00
> > END
> > The attempt to set the linecap property
> > $styleObj-> set('linecap', 'butt' );
> > results in
> > LINECAP NONE
> > Specifying it as integer completely removes the property.
> > Can someone please advice if these are bugs or if I am doing
> > something
> > wrong as this is not documented?
> > Thank you very much
> > Nicol
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/mapserver-users
