[mapserver-users] Trouble when serving mapcache WMTS to ArcMap clients - custom
Passmore, James H.
jpass at bgs.ac.uk
Thu Jul 11 09:19:17 PDT 2019
I see you have in the GetCapabilities file <ows:SupportedCRS>urn:ogc:def:crs:EPSG:6.3:103744</ows:SupportedCRS>
That's surely wrong, as 103744 is not a valid EPSG code, but one defined by ESRI (https://github.com/Esri/projection-engine-db-doc/blob/master/proj4/esri)
I'm not sure if it would work if you stated it like urn:ogc:def:crs:ESRI::103744 or just ESRI::103744, but it's possible that ArcMap is trying to do an EPSG lookup, failing and reverting to WGS84
James
Message: 1
Date: Wed, 10 Jul 2019 18:43:05 +0000
To: "mapserver-users at lists.osgeo.org"
<mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] Trouble when serving mapcache WMTS to
ArcMap clients - custom county projection for Minnesota?
Message-ID: <6290ae2cff5b4550891c4480d2eb837f at co.lyon.mn.us>
Content-Type: text/plain; charset="utf-8"
Hello,
I am having trouble serving a Mapserver / Mapcache WMTS service to ArcMAP clients when using my counties projection which is 103749 for Lyon County, MN. At most tile zoom levels the air photo are further South than where they should otherwise be located. The only exception is that around 1:6000 the image lines up perfectly. When I connect ArcMAP to the Mapcache Service using WMS the service works fine however ArcGIS wants to consume the service in WGS_84 instead of county projections.
Is there anything I need to do so that my WMTS service works better between MapServer(Mapcache), ArcGIS, and possibly QGIS?
Reference:
http://geomoose.lyonco.org/mapcache/wmts/1.0.0/WMTSCapabilities.xml
Thank You!
Sincerely,
Mark Volz, GISP
Lyon County GIS Coordinator
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system.
UK Research and Innovation has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UK Research and Innovation does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Opinions, conclusions or other information in this message and attachments that are not related directly to UK Research and Innovation business are solely those of the author and do not represent the views of UK Research and Innovation.
More information about the MapServer-users
