[mapserver-users] PostGIS layer projection
Radim Blazek
radim.blazek at gmail.com
Thu Jul 18 01:59:06 PDT 2019
can you please explain how does re-projection of PostGIS layers work?
If there is a POSTGIS layer with DATA without "using srid=" but
PostGIS column has SRID defined, there is constraint for that SRID on
the column and geometries have SRID set, is it necessary to define
PROJECTION for that layer if SRID of the column is different from that
of mapfile?
For example, geometry column has SRID=4326, geometries have SRID set, mapfile:
NAME test
PROJECTION
"init=epsg:3857"
END
LAYER test
CONNECTIONTYPE postgis
DATA "geo FROM test"
END
END
if a request comes to render a map in 3857, will be geometries
re-projected correctly from 4326 to 3857?
Radim
More information about the MapServer-users
