[mapserver-users] ows_denied_ip_list is working ?
Andrea Peri
aperi2007 at gmail.com
Tue Jul 30 12:30:03 PDT 2019
I was using a compiled version from a recent clone of master .
I try to apply ot to WEB-> METADATA section section using this kind of
values:
I try to use a list of IP directly listed using a space as separator
"ows_denied_ip_list" "xxx.xxx.xxx.xxx yyy.yyy.yyy.yyy zzz.zzz.zzz.zzz"
or using a file where there is the same list one IP for line
"ows_denied_ip_list" "file:/path-to-file/file-with-ip-list.txt"
The values listed are the possibly values of our proxy.
So I guess setting them as denied IP mapserver should refuse to give a map
to every client wms using them.
Instead the map are still showed.
I'm using QGIS as wms client to test it.
A.
Il mar 30 lug 2019, 04:21 Lime, Steve D (MNIT) <steve.lime at state.mn.us> ha
scritto:
> I will test and reply back. What specific version, config and tests did
> you try on your end?
> *From:* mapserver-users <mapserver-users-bounces at lists.osgeo.org> on
> behalf of Andrea Peri <aperi2007 at gmail.com>
> *Sent:* Saturday, July 27, 2019 9:02:07 AM
> *To:* mapserver-users at lists.osgeo.org <mapserver-users at lists.osgeo.org>
> *Subject:* [mapserver-users] ows_denied_ip_list is working ?
> *This message may be from an external email source.*
> Do not select links or open attachments unless verified. Report all
> suspicious emails to Minnesota IT Services Security Operations Center.
> Hi,
> I see my version of mapserver don't work the ows_denied_ip_list.
> I see ths other mex:
> http://osgeo-org.1560.x6.nabble.com/ows-allowed-ip-list-ows-denied-ip-list-not-working-td5202667.html
> <https://gcc01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fosgeo-org.1560.x6.nabble.com%2Fows-allowed-ip-list-ows-denied-ip-list-not-working-td5202667.html&data=02%7C01%7Csteve.lime%40state.mn.us%7C90724c9fc7d94d42158308d7129b0d4e%7Ceb14b04624c445198f26b89c2159828c%7C0%7C0%7C636998329472766840&sdata=TSVAPD7mBaTxr0tsTapcB8n7s7VJ%2BP%2B1hZ14zaEMndI%3D&reserved=0>
> I try all the same option but nothing is work.
> So I guess that instead that the ows_denied_ip_list was dismissed.
> Is this confirmed ?
> Thx.
> A.
> Andrea Peri
> qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190730/5f654aa1/attachment.html>
