[mapserver-users] Can I skip logging MS_NOTFOUND errors?
lars.schylberg at blixtmail.se lars.schylberg at blixtmail.se
Wed Jun 5 01:18:08 PDT 2019
Does it make a difference if You define:
CONFIG 'ON_MISSING_DATA' 'IGNORE'
on the map level?
/Lars S.
4 juni 2019 kl. 21:44, "Peter Schmitt" <pschmitt at gmail.com (mailto:pschmitt at gmail.com?to=%22Peter%20Schmitt%22%20<pschmitt at gmail.com>)> skrev:
I have MapServer configured to serve a WFS endpoint with GeoJSON. The data itself is in a PostGIS database. When I make a query for data that's non-existent, I get an empty feature collection:
> curl http://localhost/mapserv?service=WFS&VERSION=1.1.0&REQUEST=getfeature&typename=some_layer&srsname=EPSG:4326&OUTPUTFORMAT=geojson&some_runtime_substitution_parameter=42 (http://localhost/mapserv?service=WFS&VERSION=1.1.0&REQUEST=getfeature&typename=some_layer&srsname=EPSG:4326&OUTPUTFORMAT=geojson&some_runtime_substitution_parameter=42)
> "type": "FeatureCollection",
> "name": "some_layer",
> "features": []
This works as anticipated. What I didn't expect is that MapServer logs an error:
> msQueryByRect(): Search returned no results. No matching record(s) found
I think this code is being invoked: https://github.com/mapserver/mapserver/blob/master/mapquery.c#L1287-L1288 (https://github.com/mapserver/mapserver/blob/master/mapquery.c#L1287-L1288)
I do not think having no results should be considered an error. Is there a way to silence just this one type of error? I couldn't find anything obvious other than other than redirecting stderr to /dev/null or remove it via grep/sed.
Thanks,
Pete
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190605/0b46b2a7/attachment.htm>
More information about the MapServer-users mailing list
