[mapserver-users] Cannot compile mapserver 7 with postgis
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jun 18 05:26:13 PDT 2019
You are likely missing a switch at the cmake command, such as:
cmake -DPOSTGRESQL_LIBRARY=/usr/local/pgsql/lib/libpq.so -DWITH_POSTGIS=1
Make sure you also install the dev libs for PostgreSQL, such as:
sudo apt-get install postgresql-server-dev-10
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2019-06-18 9:05 AM, Sebastiano Laini wrote:
> Hi all,
> I’m trying to compile MapServer 7 with:
> Proj 6
> Geos 3.7
> Gdal 3.0
> PostGis 2.5
> Postgres 10
> But for some reason it complaining about pg_config not found, I usually
> use /usr/pgsql-10/bin/pg_config to compile software that need the same
> file but with MapServer 7 I can’t
> Here my cmake :
> cmake -DCMAKE_INSTALL_PREFIX=/opt \
> -DCMAKE_PREFIX_PATH=/usr/pgsql-10/bin:/usr/local/src/postgis-2.5.2:/usr/local:/opt:/usr/local/src
> -DWITH_CLIENT_WFS=ON \
> -DWITH_CLIENT_WMS=ON \
> -DWITH_CURL=ON \
> -DWITH_SOS=ON \
> -DWITH_FCGI=0 \
> -DWITH_PERL=0 \
> -DWITH_RUBY=0 \
> -DWITH_JAVA=0 \
> -DWITH_CSHARP=0 \
> -DWITH_PYTHON=0 \
> -DWITH_SVGCAIRO=0 \
> -DWITH_FRIBIDI=0 \
> -DWITH_PROTOBUFC=0 \
> -DWITH_CAIRO=0 \
> -DWITH_HARFBUZZ=0 \
> -DWITH_ORACLESPATIAL=0 \
> -DWITH_MSSQL2008=0 \
> ../ >../configure.out.txt
> How can I compile it with PostGis support?
> Sebastiano Laini
> Web Developer
> Buchanan Computing
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
