[mapserver-users] WCS 2.0.1 not returning same image as WCS 1.0.0
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Wed Jun 5 13:36:06 PDT 2019
I recommend to read the WCS 2.0 core standard which does not support bbox, resx or resy anymore. Mapserver documentation shows also how to use SUBSET https://www.mapserver.org/ogc/wcs_server.html. If you need to change the pixel size then the document to read is the WCS Scaling extension standard https://portal.opengeospatial.org/files/12-039.
-Jukka Rahkonen-
Lähettäjä: mapserver-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Moisan, Yves (NRCAN/RNCAN)
Lähetetty: keskiviikko 5. kesäkuuta 2019 21.05
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] WCS 2.0.1 not returning same image as WCS 1.0.0
Hi All,
On Ubuntu 18.04 with :
MapServer version 7.0.7 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
When I issue a GetCoverage in WCS 1.0.1 I get a 1635 X 1940 pixels GTiff image :
http://myserver?SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCoverage&COVERAGE=myCoverage&bbox=376509,4898728,377163,4899504&crs=EPSG:26918&resx=0.4&resy=0.4&FORMAT=image/tiff
The same request, only in 2.0.1 and with COVERAGEID instead of COVERAGE, I get :
msWCSGetCoverage20(): WCS server error. Raster size out of range, width and height of resulting coverage must be no more than MAXSIZE=4096.
How can that be ? I'm specifying resx resy to the values pixels have in the image behind the service (and when I overlay the image I get back from the WCS 1.0.0 call it matches the original image pixel for pixel) so there can't be interpolation going on here. I'm surprised.
Thanx for pointers,
Yves
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190605/29a0f08b/attachment.html>
