[mapserver-users] Recommendations for SVG Sizing in MAPSERVER?
Lime, Steve D (MNIT) steve.lime at state.mn.us
Thu Jun 27 12:02:22 PDT 2019
I don't believe you can muck with the SVG color since SVG can carry multiple elements and colors. That complexity doesn't map very well to a single color value in a styleObj. It's probably best to consider SVG as immutable, same as an image symbol. You can use truetype fonts (or vector symbols) if you want something scaleable where you can alter color.
--Steve
Sent: Thursday, June 27, 2019 12:35 PM
To: Lime, Steve D (MNIT) <steve.lime at state.mn.us>; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Recommendations for SVG Sizing in MAPSERVER?
This message may be from an external email source.
Do not select links or open attachments unless verified. Report all suspicious emails to Minnesota IT Services Security Operations Center.
Hi Steve,
Thanks for the tip. I used the link you provided and was able to get the SVG symbol sizing to a reasonable level. I appreciate the help.
I did have another question, maybe you know this. In the most recent version MAPSERVER, are we able to change the color of SVGs using the COLOR parameter? It does not seem that we are able to do so. I found a couple topics on the forum but they were from a few years ago. I am not sure if anything has changed or if I am missing something.  Maybe you know the answer to this as well? Thanks for your help!
On Tue, Jun 25, 2019, at 1:50 PM, Lime, Steve D (MNIT) wrote:
Hi Brian: Welcome! My guess that the SVG file might be "sized" to whatever page size you had defined in Inkscape and your elements may be significantly smaller than that. Basically I'm wondering if there's a bunch of empty space that is also being scaled and your actual symbol would appear proportionately smaller as well. If this is the case it looks like you can do things in Inkscape to remove that space...
  https://graphicdesign.stackexchange.com/questions/21635/getting-rid-of-whitespace-in-inkscape
--Steve
-----Original Message-----
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Brian Stice
Sent: Monday, June 24, 2019 2:46 PM
To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] Recommendations for SVG Sizing in MAPSERVER?
Hello,
I am fairly new with MapServer and was wondering if anyone had any recommendations or guidelines of sizing point symbol SVG's?
I created some SVG symbols in Inkscape. When I load them into MapServer and choose SIZEUNITS feet, I have to set the actual symbol size to around 500 for these to show up in a Map. My understanding is that the SIZEUNIT parameter changes the way the symbol rendered in real world space (in my case feet rather than pixels). I am not sure if this has to do with how the SVG is sized in Inkscape or if there is an issue with using SIZEUNITS and SVGs together in MapServer. I looked at the MAPSERVER documentation online and did not have much luck.
I have tried a few things including setting the MIN and MAX Size with no luck. Any help or pointers would be awesome.
Sincerely,
**Brian Stice ***GISP****
**Project Implementation Manager | PeopleGIS*
500 West Cummings Park, Suite 3900
Woburn, MA 01801
P: 617.625.3608
www.peoplegis.com<http://www.peoplegis.com>
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
Brian Stice GISP
Woburn, MA 01801
P: 617.625.3608
www.peoplegis.com<https://gcc01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.peoplegis.com&data=02%7C01%7Csteve.lime%40state.mn.us%7C79a47f9dda454b849b6a08d6fb25d42c%7Ceb14b04624c445198f26b89c2159828c%7C0%7C1%7C636972537227731679&sdata=aiwCP6EoEA%2FLKsdLS7t%2FjTBmyXPNLSWSx%2ByidIxGmME%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190627/cc796778/attachment.htm>
More information about the MapServer-users mailing list
