[mapserver-users] Help with Mapserver and MySQL
Carlos Neves (LREC)
cneves at lrec.pt
Fri Jun 28 04:04:07 PDT 2019
Hi List,
I need to connect a shapefile map to a mysql external numeric table.
The goal is display in a mapserver map real time values from a
meteorological network M2M stations.
This is one of my mapfile with JOIN:
DATA "basins.shp"
JOIN
NAME test
CONNECTIONTYPE MYSQL
CONNECTION '192.168.3.20:user:passwd:meteodata'
TABLE "meteo"
FROM "BASINCODE"
TO "code"
TYPE ONE-TO-ONE
END # join
I have tried LABELITEM "test_mysqlfield" or TEXT ( [test_mysqlfield])
but the result is an unknown error and stops mapserv CGI. I have DEBUG
5 level but no errors in log files.
So, I have tried another way with a OGR connection:
CONNECTIONTYPE OGR
CONNECTION "basins.shp"
DATA "SELECT * FROM basins LEFT JOIN
'MYSQL:meteodata,host=192.168.3.20,user=user,password=passwd'.meteo ON
basins.BASINCODE = meteo.code"
now LABELITEM "mysqlfield" or TEXT ([mysqlfield]) doesn't have any
error, but the values display "0" (zero) in the Map label points.
Any idea? Any help would be much appreciated
Carlos
