[mapserver-users] Having an issue displaying a VRT file
Stephen Woodbridge
stephenwoodbridge37 at gmail.com
Sat Jun 29 09:52:56 PDT 2019
Never mind! I figured it out.
If your MAP->NAME is the same as you LAYER->NAME then that take priority
over of LAYER->NAME and then display all the other layers also. In this
case rendering the the gray scale tif over the colors.
-Steve
On 6/29/2019 12:22 PM, Stephen Woodbridge wrote:
> Hi all,
> I've been banging my head against this problem for a while so asking
> for ideas.
> Thanks,
> -Steve W
> I have GTiff file the looks like:
> $ gdalinfo -stats -hist /maps/wms/data/VIIRS_CHLORA/VIIRS_CHLORA.tif
> Driver: GTiff/GeoTIFF
> Files: /maps/wms/data/VIIRS_CHLORA/VIIRS_CHLORA.tif
> Size is 8010, 6000
> Coordinate System is:
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]]
> Origin = (-120.033749999999998,44.883749999999999)
> Pixel Size = (0.007500000000000,-0.007500000000000)
> Metadata:
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left (-120.0337500, 44.8837500) (120d 2' 1.50"W, 44d53' 1.50"N)
> Lower Left (-120.0337500, -0.1162500) (120d 2' 1.50"W, 0d 6'58.50"S)
> Upper Right ( -59.9587500, 44.8837500) ( 59d57'31.50"W, 44d53' 1.50"N)
> Lower Right ( -59.9587500, -0.1162500) ( 59d57'31.50"W, 0d 6'58.50"S)
> Center ( -89.9962500, 22.3837500) ( 89d59'46.50"W, 22d23' 1.50"N)
> Band 1 Block=8010x1 Type=Float32, ColorInterp=Gray
> Minimum=0.001, Maximum=392.112, Mean=0.682, StdDev=6.289
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> 256 buckets from -0.767845 to 392.881:
> 5116420 228446 61443 29479 20356 13649 8567 6328 4568 3350 2637 2397
> 1852 1682 1516 1391 1404 1193 1074 957 874 824 791 663 566 560 574 545
> 531 466 368 369 379 263 334 301 267 252 250 247 202 178 183 207 195
> 184 155 163 166 184 152 151 150 138 101 128 131 140 85 113 98 121 127
> 106 83 92 92 107 81 87 81 72 110 77 68 62 70 59 80 75 75 76 55 55 50
> 51 66 56 59 44 50 52 60 43 55 52 57 54 35 60 47 35 41 30 38 37 47 49
> 22 37 25 40 25 36 37 43 39 27 22 32 34 33 33 27 32 32 20 22 26 14 25
> 21 26 14 16 21 12 26 15 29 23 18 20 5 9 10 9 16 17 12 14 20 19 12 16
> 17 10 8 11 21 11 21 7 10 16 18 10 11 17 21 11 6 7 11 11 17 3 16 8 6 9
> 19 17 9 11 11 10 11 9 8 6 16 11 12 14 12 9 11 8 6 8 7 14 10 6 3 4 3 5
> 7 4 6 5 9 5 5 2 6 10 14 4 4 6 3 5 3 8 3 5 10 7 1 13 14 9 7 5 6 9 9 6 5
> 10 8 6 7 5 10 11 9 7 4 0 5 0 4
> NoData Value=-999
> Metadata:
> STATISTICS_MAXIMUM=392.11212158203
> STATISTICS_MEAN=0.68159060504688
> STATISTICS_MINIMUM=0.0010000000474975
> STATISTICS_STDDEV=6.2888244425479
> I created a VRT file with that looks like:
> a$ gdalinfo -stats -hist /maps/wms/data/VIIRS_CHLORA/VIIRS_CHLORA.vrt
> Driver: VRT/Virtual Raster
> Files: /maps/wms/data/VIIRS_CHLORA/VIIRS_CHLORA.vrt
> Size is 8010, 6000
> Coordinate System is `'
> Corner Coordinates:
> Band 1 Block=128x128 Type=Byte, ColorInterp=Palette
> 256 buckets from -0.5 to 255.5:
> 4946628 325638 83015 39917 25684 16759 13604 10800 8041 5808 4731
> 3922 3191 2501 2130 1883 1639 1488 1266 1159 1070 1070 935 916 887 873
> 833 713 679 620 624 541 544 535 492 445 427 351 364 390 359 389 315
> 347 316 305 229 263 221 252 189 183 219 210 183 180 173 175 149 166
> 156 141 123 124 115 124 133 132 119 117 106 110 95 112 119 113 117 98
> 101 95 89 101 86 61 80 85 75 95 90 60 56 75 68 59 89 67 92 65 60 45 76
> 66 52 60 67 50 61 55 48 41 63 73 56 47 42 42 45 35 46 42 44 57 46 52
> 42 57 27 43 31 33 39 27 38 50 31 43 35 22 26 38 41 36 27 29 39 38 29
> 45 29 32 35 22 41 33 31 23 25 28 15 26 24 17 28 31 42 23 11 20 24 17
> 26 21 12 27 22 25 26 27 27 20 19 15 17 18 16 27 25 25 15 19 22 21 15
> 16 16 18 9 19 10 11 18 17 11 16 10 13 6 14 19 4 11 17 8 18 18 14 15 11
> 15 9 2 5 4 9 9 2 9 13 10 7 10 10 16 12 10 10 9 8 11 10 7 2 7 10 14 7 7
> 14 11 5 7 5 14 15 5 735
> Metadata:
> Color Table (RGB with 256 entries)
> 0: 0,0,0,255
> 1: 0,0,255,255
> 254: 0,0,0,255
> 255: 255,255,255,255
> When I display if via mapserver it comes out all black:
> LAYER
> NAME "chlorophyll"
> STATUS on
> TYPE raster
> DATA "/maps/wms/data/VIIRS_CHLORA/VIIRS_CHLORA.vrt"
> PROJECTION "init=epsg:4326" END
> END
> But if I run:
> gdal_translate -of PNG
> /maps/wms/data/VIIRS_CHLORA/VIIRS_CHLORA.vrt test.png
> test.png shows the image with the colors!
> The whole VRT file is:
> <VRTDataset rasterXSize="8010" rasterYSize="6000">
> <GeoTransform> -120.03375 ,0.0075 , 0 , 44.88375 , 0 , -0.0075
> </GeoTransform>
> <Metadata>
> </Metadata>
> <VRTRasterBand dataType="Byte" band="1">
> <ColorInterp>Palette</ColorInterp>
> <SourceNoData>-999.0</SourceNoData>
> <ColorTable>
> <Entry c1="0" c2="0" c3="0" c4="255"/>
> <Entry c1="0" c2="0" c3="255" c4="255"/>
> <Entry c1="100" c2="150" c3="240" c4="255"/>
> <Entry c1="0" c2="200" c3="0" c4="255"/>
> <Entry c1="255" c2="255" c3="255" c4="255"/>
> <Entry c1="250" c2="250" c3="0" c4="255"/>
> <Entry c1="255" c2="0" c3="0" c4="255"/>
> <Entry c1="255" c2="120" c3="0" c4="255"/>
> <Entry c1="225" c2="0" c3="225" c4="255"/>
> <Entry c1="120" c2="120" c3="120" c4="255"/>
> <Entry c1="255" c2="230" c3="255" c4="255"/>
> <Entry c1="255" c2="227" c3="255" c4="255"/>
> <Entry c1="255" c2="224" c3="255" c4="255"/>
> <Entry c1="255" c2="222" c3="255" c4="255"/>
> <Entry c1="255" c2="219" c3="255" c4="255"/>
> <Entry c1="255" c2="216" c3="255" c4="255"/>
> <Entry c1="255" c2="214" c3="255" c4="255"/>
> <Entry c1="255" c2="211" c3="255" c4="255"/>
> <Entry c1="255" c2="209" c3="255" c4="255"/>
> <Entry c1="255" c2="206" c3="255" c4="255"/>
> <Entry c1="255" c2="203" c3="255" c4="255"/>
> <Entry c1="255" c2="201" c3="255" c4="255"/>
> <Entry c1="255" c2="198" c3="255" c4="255"/>
> <Entry c1="255" c2="195" c3="255" c4="255"/>
> <Entry c1="255" c2="193" c3="255" c4="255"/>
> <Entry c1="255" c2="190" c3="255" c4="255"/>
> <Entry c1="255" c2="188" c3="255" c4="255"/>
> <Entry c1="255" c2="185" c3="255" c4="255"/>
> <Entry c1="255" c2="182" c3="255" c4="255"/>
> <Entry c1="255" c2="180" c3="255" c4="255"/>
> <Entry c1="255" c2="177" c3="255" c4="255"/>
> <Entry c1="255" c2="175" c3="255" c4="255"/>
> <Entry c1="252" c2="166" c3="255" c4="255"/>
> <Entry c1="249" c2="158" c3="255" c4="255"/>
> <Entry c1="247" c2="150" c3="255" c4="255"/>
> <Entry c1="244" c2="141" c3="255" c4="255"/>
> <Entry c1="241" c2="133" c3="255" c4="255"/>
> <Entry c1="239" c2="125" c3="255" c4="255"/>
> <Entry c1="236" c2="116" c3="255" c4="255"/>
> <Entry c1="234" c2="108" c3="255" c4="255"/>
> <Entry c1="231" c2="100" c3="255" c4="255"/>
> <Entry c1="228" c2="91" c3="255" c4="255"/>
> <Entry c1="226" c2="83" c3="255" c4="255"/>
> <Entry c1="223" c2="75" c3="255" c4="255"/>
> <Entry c1="220" c2="66" c3="255" c4="255"/>
> <Entry c1="218" c2="58" c3="255" c4="255"/>
> <Entry c1="215" c2="50" c3="255" c4="255"/>
> <Entry c1="213" c2="41" c3="255" c4="255"/>
> <Entry c1="210" c2="33" c3="255" c4="255"/>
> <Entry c1="207" c2="25" c3="255" c4="255"/>
> <Entry c1="205" c2="16" c3="255" c4="255"/>
> <Entry c1="202" c2="8" c3="255" c4="255"/>
> <Entry c1="200" c2="0" c3="255" c4="255"/>
> <Entry c1="193" c2="0" c3="252" c4="255"/>
> <Entry c1="187" c2="0" c3="249" c4="255"/>
> <Entry c1="181" c2="0" c3="247" c4="255"/>
> <Entry c1="175" c2="0" c3="244" c4="255"/>
> <Entry c1="169" c2="0" c3="241" c4="255"/>
> <Entry c1="162" c2="0" c3="239" c4="255"/>
> <Entry c1="156" c2="0" c3="236" c4="255"/>
> <Entry c1="150" c2="0" c3="234" c4="255"/>
> <Entry c1="144" c2="0" c3="231" c4="255"/>
> <Entry c1="138" c2="0" c3="228" c4="255"/>
> <Entry c1="131" c2="0" c3="226" c4="255"/>
> <Entry c1="125" c2="0" c3="223" c4="255"/>
> <Entry c1="119" c2="0" c3="220" c4="255"/>
> <Entry c1="113" c2="0" c3="218" c4="255"/>
> <Entry c1="107" c2="0" c3="215" c4="255"/>
> <Entry c1="100" c2="0" c3="213" c4="255"/>
> <Entry c1="94" c2="0" c3="210" c4="255"/>
> <Entry c1="88" c2="0" c3="207" c4="255"/>
> <Entry c1="82" c2="0" c3="205" c4="255"/>
> <Entry c1="76" c2="0" c3="202" c4="255"/>
> <Entry c1="70" c2="0" c3="200" c4="255"/>
> <Entry c1="66" c2="0" c3="202" c4="255"/>
> <Entry c1="63" c2="0" c3="205" c4="255"/>
> <Entry c1="60" c2="0" c3="207" c4="255"/>
> <Entry c1="56" c2="0" c3="210" c4="255"/>
> <Entry c1="53" c2="0" c3="213" c4="255"/>
> <Entry c1="50" c2="0" c3="215" c4="255"/>
> <Entry c1="46" c2="0" c3="218" c4="255"/>
> <Entry c1="43" c2="0" c3="220" c4="255"/>
> <Entry c1="40" c2="0" c3="223" c4="255"/>
> <Entry c1="36" c2="0" c3="226" c4="255"/>
> <Entry c1="33" c2="0" c3="228" c4="255"/>
> <Entry c1="30" c2="0" c3="231" c4="255"/>
> <Entry c1="26" c2="0" c3="234" c4="255"/>
> <Entry c1="23" c2="0" c3="236" c4="255"/>
> <Entry c1="20" c2="0" c3="239" c4="255"/>
> <Entry c1="16" c2="0" c3="241" c4="255"/>
> <Entry c1="13" c2="0" c3="244" c4="255"/>
> <Entry c1="10" c2="0" c3="247" c4="255"/>
> <Entry c1="6" c2="0" c3="249" c4="255"/>
> <Entry c1="3" c2="0" c3="252" c4="255"/>
> <Entry c1="0" c2="12" c3="255" c4="255"/>
> <Entry c1="0" c2="24" c3="255" c4="255"/>
> <Entry c1="0" c2="36" c3="255" c4="255"/>
> <Entry c1="0" c2="48" c3="255" c4="255"/>
> <Entry c1="0" c2="60" c3="255" c4="255"/>
> <Entry c1="0" c2="72" c3="255" c4="255"/>
> <Entry c1="0" c2="85" c3="255" c4="255"/>
> <Entry c1="0" c2="97" c3="255" c4="255"/>
> <Entry c1="0" c2="109" c3="255" c4="255"/>
> <Entry c1="0" c2="121" c3="255" c4="255"/>
> <Entry c1="0" c2="133" c3="255" c4="255"/>
> <Entry c1="0" c2="145" c3="255" c4="255"/>
> <Entry c1="0" c2="157" c3="255" c4="255"/>
> <Entry c1="0" c2="170" c3="255" c4="255"/>
> <Entry c1="0" c2="182" c3="255" c4="255"/>
> <Entry c1="0" c2="194" c3="255" c4="255"/>
> <Entry c1="0" c2="206" c3="255" c4="255"/>
> <Entry c1="0" c2="218" c3="255" c4="255"/>
> <Entry c1="0" c2="230" c3="255" c4="255"/>
> <Entry c1="0" c2="242" c3="255" c4="255"/>
> <Entry c1="0" c2="255" c3="255" c4="255"/>
> <Entry c1="0" c2="255" c3="242" c4="255"/>
> <Entry c1="0" c2="255" c3="230" c4="255"/>
> <Entry c1="0" c2="255" c3="218" c4="255"/>
> <Entry c1="0" c2="255" c3="206" c4="255"/>
> <Entry c1="0" c2="255" c3="194" c4="255"/>
> <Entry c1="0" c2="255" c3="182" c4="255"/>
> <Entry c1="0" c2="255" c3="170" c4="255"/>
> <Entry c1="0" c2="255" c3="157" c4="255"/>
> <Entry c1="0" c2="255" c3="145" c4="255"/>
> <Entry c1="0" c2="255" c3="133" c4="255"/>
> <Entry c1="0" c2="255" c3="121" c4="255"/>
> <Entry c1="0" c2="255" c3="109" c4="255"/>
> <Entry c1="0" c2="255" c3="97" c4="255"/>
> <Entry c1="0" c2="255" c3="85" c4="255"/>
> <Entry c1="0" c2="255" c3="72" c4="255"/>
> <Entry c1="0" c2="255" c3="60" c4="255"/>
> <Entry c1="0" c2="255" c3="48" c4="255"/>
> <Entry c1="0" c2="255" c3="36" c4="255"/>
> <Entry c1="0" c2="255" c3="24" c4="255"/>
> <Entry c1="0" c2="255" c3="12" c4="255"/>
> <Entry c1="0" c2="255" c3="0" c4="255"/>
> <Entry c1="12" c2="255" c3="0" c4="255"/>
> <Entry c1="24" c2="255" c3="0" c4="255"/>
> <Entry c1="36" c2="255" c3="0" c4="255"/>
> <Entry c1="48" c2="255" c3="0" c4="255"/>
> <Entry c1="60" c2="255" c3="0" c4="255"/>
> <Entry c1="72" c2="255" c3="0" c4="255"/>
> <Entry c1="85" c2="255" c3="0" c4="255"/>
> <Entry c1="97" c2="255" c3="0" c4="255"/>
> <Entry c1="109" c2="255" c3="0" c4="255"/>
> <Entry c1="121" c2="255" c3="0" c4="255"/>
> <Entry c1="133" c2="255" c3="0" c4="255"/>
> <Entry c1="145" c2="255" c3="0" c4="255"/>
> <Entry c1="157" c2="255" c3="0" c4="255"/>
> <Entry c1="170" c2="255" c3="0" c4="255"/>
> <Entry c1="182" c2="255" c3="0" c4="255"/>
> <Entry c1="194" c2="255" c3="0" c4="255"/>
> <Entry c1="206" c2="255" c3="0" c4="255"/>
> <Entry c1="218" c2="255" c3="0" c4="255"/>
> <Entry c1="230" c2="255" c3="0" c4="255"/>
> <Entry c1="242" c2="255" c3="0" c4="255"/>
> <Entry c1="255" c2="255" c3="0" c4="255"/>
> <Entry c1="255" c2="252" c3="2" c4="255"/>
> <Entry c1="255" c2="249" c3="4" c4="255"/>
> <Entry c1="255" c2="247" c3="7" c4="255"/>
> <Entry c1="255" c2="244" c3="9" c4="255"/>
> <Entry c1="255" c2="241" c3="11" c4="255"/>
> <Entry c1="255" c2="239" c3="14" c4="255"/>
> <Entry c1="255" c2="236" c3="16" c4="255"/>
> <Entry c1="255" c2="234" c3="19" c4="255"/>
> <Entry c1="255" c2="231" c3="21" c4="255"/>
> <Entry c1="255" c2="228" c3="23" c4="255"/>
> <Entry c1="255" c2="226" c3="26" c4="255"/>
> <Entry c1="255" c2="223" c3="28" c4="255"/>
> <Entry c1="255" c2="220" c3="30" c4="255"/>
> <Entry c1="255" c2="218" c3="33" c4="255"/>
> <Entry c1="255" c2="215" c3="35" c4="255"/>
> <Entry c1="255" c2="213" c3="38" c4="255"/>
> <Entry c1="255" c2="210" c3="40" c4="255"/>
> <Entry c1="255" c2="207" c3="42" c4="255"/>
> <Entry c1="255" c2="205" c3="45" c4="255"/>
> <Entry c1="255" c2="202" c3="47" c4="255"/>
> <Entry c1="255" c2="200" c3="50" c4="255"/>
> <Entry c1="255" c2="190" c3="47" c4="255"/>
> <Entry c1="255" c2="180" c3="45" c4="255"/>
> <Entry c1="255" c2="171" c3="42" c4="255"/>
> <Entry c1="255" c2="161" c3="40" c4="255"/>
> <Entry c1="255" c2="152" c3="38" c4="255"/>
> <Entry c1="255" c2="142" c3="35" c4="255"/>
> <Entry c1="255" c2="133" c3="33" c4="255"/>
> <Entry c1="255" c2="123" c3="30" c4="255"/>
> <Entry c1="255" c2="114" c3="28" c4="255"/>
> <Entry c1="255" c2="104" c3="26" c4="255"/>
> <Entry c1="255" c2="95" c3="23" c4="255"/>
> <Entry c1="255" c2="85" c3="21" c4="255"/>
> <Entry c1="255" c2="76" c3="19" c4="255"/>
> <Entry c1="255" c2="66" c3="16" c4="255"/>
> <Entry c1="255" c2="57" c3="14" c4="255"/>
> <Entry c1="255" c2="47" c3="11" c4="255"/>
> <Entry c1="255" c2="38" c3="9" c4="255"/>
> <Entry c1="255" c2="28" c3="7" c4="255"/>
> <Entry c1="255" c2="19" c3="4" c4="255"/>
> <Entry c1="255" c2="9" c3="2" c4="255"/>
> <Entry c1="250" c2="0" c3="0" c4="255"/>
> <Entry c1="245" c2="0" c3="0" c4="255"/>
> <Entry c1="241" c2="0" c3="0" c4="255"/>
> <Entry c1="236" c2="0" c3="0" c4="255"/>
> <Entry c1="232" c2="0" c3="0" c4="255"/>
> <Entry c1="227" c2="0" c3="0" c4="255"/>
> <Entry c1="223" c2="0" c3="0" c4="255"/>
> <Entry c1="218" c2="0" c3="0" c4="255"/>
> <Entry c1="214" c2="0" c3="0" c4="255"/>
> <Entry c1="209" c2="0" c3="0" c4="255"/>
> <Entry c1="205" c2="0" c3="0" c4="255"/>
> <Entry c1="200" c2="0" c3="0" c4="255"/>
> <Entry c1="196" c2="0" c3="0" c4="255"/>
> <Entry c1="191" c2="0" c3="0" c4="255"/>
> <Entry c1="187" c2="0" c3="0" c4="255"/>
> <Entry c1="182" c2="0" c3="0" c4="255"/>
> <Entry c1="178" c2="0" c3="0" c4="255"/>
> <Entry c1="173" c2="0" c3="0" c4="255"/>
> <Entry c1="169" c2="0" c3="0" c4="255"/>
> <Entry c1="164" c2="0" c3="0" c4="255"/>
> <Entry c1="160" c2="0" c3="0" c4="255"/>
> <Entry c1="156" c2="0" c3="0" c4="255"/>
> <Entry c1="152" c2="0" c3="0" c4="255"/>
> <Entry c1="149" c2="0" c3="0" c4="255"/>
> <Entry c1="145" c2="0" c3="0" c4="255"/>
> <Entry c1="141" c2="0" c3="0" c4="255"/>
> <Entry c1="138" c2="0" c3="0" c4="255"/>
> <Entry c1="134" c2="0" c3="0" c4="255"/>
> <Entry c1="130" c2="0" c3="0" c4="255"/>
> <Entry c1="127" c2="0" c3="0" c4="255"/>
> <Entry c1="123" c2="0" c3="0" c4="255"/>
> <Entry c1="120" c2="0" c3="0" c4="255"/>
> <Entry c1="116" c2="0" c3="0" c4="255"/>
> <Entry c1="112" c2="0" c3="0" c4="255"/>
> <Entry c1="109" c2="0" c3="0" c4="255"/>
> <Entry c1="105" c2="0" c3="0" c4="255"/>
> <Entry c1="101" c2="0" c3="0" c4="255"/>
> <Entry c1="98" c2="0" c3="0" c4="255"/>
> <Entry c1="94" c2="0" c3="0" c4="255"/>
> <Entry c1="90" c2="0" c3="0" c4="255"/>
> <Entry c1="87" c2="0" c3="0" c4="255"/>
> <Entry c1="83" c2="0" c3="0" c4="255"/>
> <Entry c1="80" c2="0" c3="0" c4="255"/>
> </ColorTable>
> <SimpleSource>
> <SourceFilename
> relativeToVRT="0">/maps/wms/data/VIIRS_CHLORA/VIIRS_CHLORA.tif</SourceFilename>
> <SourceBand>1</SourceBand>
> <SrcRect xOff="0" yOff="0" xSize="8010" ySize="6000"/>
> <DstRect xOff="0" yOff="0" xSize="8010" ySize="6000"/>
> </SimpleSource>
> </VRTRasterBand>
> </VRTDataset>
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
