[mapserver-users] mapserver 6.2 unexpected behavior or not?
Stephen Woodbridge stephenwoodbridge37 at gmail.com
Tue Mar 5 07:59:43 PST 2019
DEFAULT means the layer will always be displayed like a background
layer, but it is dependent on MIN/MAXSCALEDENOM
ON means that if it is requested via the LAYERS=... that it can be
displayed again dependent on MIN/MAXSCALEDENOM
OFF means it will be ignored by the mapserver CGI even if its in the
LAYERS list.
OFF is useful for things like mapscript where you can define layers and
toggle them on in mapscript.
-Steve W
On 3/5/2019 7:24 AM, Sebastiano Laini wrote:
> Yesterday I came across this section
> https://mapserver.org/optimization/mapfile.html#layers
> and I don’t understand the status behaviour and MIN/MAXSCALEDENOM
> it say:
> For every layer in a Map File that has a status of ON or DEFAULT,
> MapServer will load that layer and prepare it for display, even if
> that layer never gets displayed.
> Ok, so if I setup all layers to OFF and I use MIN/MAXSCALEDENOM they
> should be displayed at their zoom level? Because I tried but is not
> work as expected in a web.
> This is one of our layer
> LAYER
>         NAME "YellowB"
>         TYPE POLYGON
>        MINSCALEDENOM 0
>        MAXSCALEDENOM 7500
>         STATUS DEFAULT
>         CONNECTIONTYPE OGR
>         CONNECTION "OpenData_Jan19/YellowBack.TAB"
>         STYLEITEM "AUTO"
>         CLASS
>                 NAME "YellowB"
>                               STYLE
> COLOR 0 0 0
>                END
>         END
>        PROJECTION
>                 "init=epsg:27700"
>         END
> END
> Should I use the PROJECTION tag in each layer even if the layer itself
> it supposed to be in that projection?
> Sebastiano Laini
> Web Developer
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
More information about the MapServer-users mailing list
