[mapserver-users] Help debugging PostGIS raster connection
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Mar 6 05:29:01 PST 2019
Great news Thomas. I also think (for good karma) all of your steps and
hints for PGraster could be added to a new wiki page in the "Tricks,
Tips, and HowTos" section of https://github.com/mapserver/mapserver/wiki
(that way people don't have to troll through thousands of email messages
to find your important tip)
thanks!
-jeff
On 2019-03-05 7:02 PM, Thomas Horner wrote:
> Great! Thanks Jeff. Turns out it was the single quotes in other parts
> of the connection string... Not sure why. Possibly special characters
> in the password or username? After removing them, I no longer have
> connection issues. With that being solved, removing the WHERE clause at
> least returns a blank image instead of an error.
> I then brought back the WHERE clause, which returned an error despite
> working in GDAL.
> This WHERE clause returns a single raster result in GDAL with the exact
> same connection string as above:
> gdalinfo "PG:.. where='timestamp=\'2019-03-05 00:00:00\''"
> However, no matter the combination of string literals, escape
> characters, and whatnot, I could not get MapServer to handle this clause
> without error.
> But wait! Enter Postgres's dollar-quoted string constants:
> where='timestamp=$$2019-03-05 00:00:00$$'
> The DATA connection string now works. Hope this helps anyone in the future.
> Regards,
> Thomas
> On Tue, Mar 5, 2019 at 3:24 PM Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> wrote:
> Hi Thomas,
> I would try the following:
> - remove all single quotes from your DATA statement (most times they
> are
> unnecessary for my use, and cause me problems)
> - remove the WHERE clause
> - also try to access another table from your database, but not raster,
> using that same DATA connection statement (I bet the problem has
> nothing
> to do with the raster table, but instead is your connection parameters)
> - verify that remote connections can access your database (check your
> file pg_hba.conf)
> hope that brings ideas and opens doors...
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> https://gatewaygeomatics.com/
> On 2019-03-04 2:38 PM, Thomas Horner wrote:
> > I have a PostGIS connection string that works fine in GDAL, as I
> get a
> > raster response when running
> > gdalinfo "PG:host=... port=5432 user='...' password='...'
> > dbname='weather_models' schema='rasters'
> > table='wpc_snow_50pct_1551268800' column='rast' mode=1
> > where='timestamp=\'2019-03-02 00:00:00\''"
> > On this very same server, I have cgi-mapserver running, and the
> output
> > from /usr/lib/cgi-bin/mapserv/ -v is
> > MapServer version 7.2.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
> SUPPORTS=PROJ
> > SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS
> > SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
> > SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> > SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> > SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS
> > INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > The problem is, when I use that same PG:... connection string as the
> > DATA for a LAYER in MapServer, I get an unhelpful error: Unable to
> > access file. Corrupt, empty or missing file '<snip of PG connection
> > string>' Couldn't establish a database connection.
> > Despite turning DEBUG level to 5, and CPL_DEBUG to ON in the MAP
> block
> > of my mapfile, I don't get any helpful debug information
> whatsoever in
> > my error log -- just the connection string and "Couldn't establish a
> > database connection." I have tried a variety of where clauses and
> other
> > tables and get the same result. I have no idea if the actual
> error is
> > coming from GDAL or MapServer, despite all those strings working
> fine
> > when running them directly via GDAL.
> > By the way, it's the same error whether I use 'timestamp'= or
> timestamp=.
> > Here is the mapfile:
> > MAP
> > CONFIG "MS_ERRORFILE" "/map/error.txt"
> > CONFIG "CPL_DEBUG" "ON"
> > DEBUG 5
> > PROJECTION
> > "init=epsg:4326"
> > END
> > LAYER
> > NAME wpc_snow_50pct
> > TYPE RASTER
> > STATUS ON
> > VALIDATION
> > "timestamp" ".*"
> > END
> > PROJECTION
> > "init=epsg:4326"
> > END
> > METADATA
> > "wms_title" "wpc_snow_50pct"
> > "wms_srs" "EPSG:4326"
> > "wms_extent" "-108.5 41 -104.5 36"
> > "wms_enable_request" "*"
> > END
> > DATA "PG:host=... port=5432 dbname='weather_models' user='...'
> > password='...' schema='rasters' table='wpc_snow_50pct_1551268800'
> > column='rast' mode=1 where='timestamp=\'2019-03-02 00:00:00\''"
> > PROCESSING "BANDS=1"
> > END
> > END
> > Any help is appreciated!
> > Thanks,
> > Thomas
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Jeff McKenna
More information about the MapServer-users
