[mapserver-users] Error While Generating Tiles
parsis presswala parsispresswala at gmail.com
Wed Mar 6 06:23:16 PST 2019
No, not yet.
On Wed, Mar 6, 2019 at 7:49 PM Yves Jacolin <yves.jacolin at camptocamp.com>
wrote:
> Did you improve Postgresql configuration (shared_buffer and work_mem
> parameters) ?
> Y.
> Le mer. 6 mars 2019 à 15:15, parsis presswala <parsispresswala at gmail.com>
> a écrit :
>> Hello,
>> I have already created indexing on some fields. Here is my indexed fields.
>> CREATE INDEX planet_osm_polygon_idx
>>   ON public.planet_osm_polygon
>>   USING btree
>>   (waterway COLLATE pg_catalog."default", "natural" COLLATE
>> pg_catalog."default", landuse COLLATE pg_catalog."default", building
>> COLLATE pg_catalog."default", aeroway COLLATE pg_catalog."default", leisure
>> COLLATE pg_catalog."default", amenity COLLATE pg_catalog."default");
>> Even I have experiment with r4.8xlarge with 32 CPU and 244 GB RAM. But
>> got same result.
>> What should I do?
>> On Wed, Mar 6, 2019 at 7:31 PM Yves Jacolin <yves.jacolin at camptocamp.com>
>> wrote:
>>> You probablty needs to create index(es) on leisure, landuse and amenity.
>>> Probably both of all but you need to do some test.
>>> Second, you probably needs to improve PostgreSQL configuration to let
>>> PostgreSQL use your 61 GB of RAM :) shared_buffers and work_mem are good
>>> parameters to look for.
>>> Y.
>>> Le mer. 6 mars 2019 à 14:56, parsis presswala <parsispresswala at gmail.com>
>>> a écrit :
>>>> Hello,
>>>> Yes I am using OSM data.
>>>> I have imported it using osm2pgsql. Database: asiadb and tables
>>>> are planet_osm_line, planet_osm_point, planet_osm_polygon, planet_osm_roads.
>>>> I have imported data of whole planet using 40 GB .osm.pbf file.
>>>> First I have only imported data of Asia and created map using
>>>> map-server, which is working fine but as soon as import data of whole
>>>> world, this problem occurred.
>>>> I have 61 GB RAM and 8 Core processor as i am working on Amazon
>>>> Elastic Compute Cloud (Amazon EC2) type r4.2xlarge.
>>>> Here is my mapfile.
>>>>  http://13.126.201.198/asiamap.map
>>>> I have run EXPLAIN <slow request> and got following result:
>>>> "Seq Scan on planet_osm_polygon  (cost=0.00..18878787.88 rows=36617920
>>>> width=277)"
>>>> "  Filter: ((leisure IS NOT NULL) OR (landuse IS NOT NULL) OR (amenity
>>>> IS NOT NULL))"
>>>> On Wed, Mar 6, 2019 at 7:04 PM Yves Jacolin <
>>>> yves.jacolin at camptocamp.com> wrote:
>>>>> Some questions that can help you :)
>>>>> is it OSM data? How do you import them?
>>>>> What is the extent of the data? Could you check if spatial indexes
>>>>> exist? Could you run EXPLAIN <your slow request> and analyze it?
>>>>> Y.
>>>>> Le mer. 6 mars 2019 à 14:29, parsis presswala <
>>>>> parsispresswala at gmail.com> a écrit :
>>>>>> Hello,
>>>>>> Here is a log of PostgreSQL. I consider that PostgreSQL takes very
>>>>>> long time to execute query on polygon. What should I do fot it?
>>>>>> 2019-03-06 11:23:49.620 UTC [2302] parsis at asiadb STATEMENT:  select
>>>>>> "highway"::text,"name"::text,"reflen"::text,"ref"::text,ST_AsBinary(ST_Force2D("way"),'NDR')
>>>>>> as geom,"nullid"::text from (select *, NULL as nullid from ( SELECT way,
>>>>>> highway, name, ref, oneway, CHAR_LENGTH(ref) AS reflen FROM planet_osm_line
>>>>>> WHERE highway IN ('motorway', 'trunk','motorway_link','trunk_link') AND
>>>>>> (name IS NOT NULL OR ref IS NOT NULL)) AS data) as nullidq where "way" &&
>>>>>> ST_GeomFromText('POLYGON((-9473834.25396072
>>>>>> 2853929.66787328,-9473834.25396072 3446928.13330971,-8880835.78852428
>>>>>> 3446928.13330971,-8880835.78852428 2853929.66787328,-9473834.25396072
>>>>>> 2853929.66787328))',900913)
>>>>>> 2019-03-06 11:24:14.911 UTC [2592] parsis at asiadb LOG:  could not
>>>>>> send data to client: Broken pipe
>>>>>> 2019-03-06 11:24:14.911 UTC [2592] parsis at asiadb STATEMENT:  select
>>>>>> "stylegroup"::text,ST_AsBinary(ST_Force2D("way"),'NDR') as
>>>>>> geom,"nullid"::text from (select *, NULL as nullid from ( SELECT way, CASE
>>>>>> WHEN leisure in
>>>>>> ('park','garden','playground','golf_course','sports_centre','pitch','stadium','nature_reserve','common')
>>>>>> THEN 'leisuree' WHEN landuse
>>>>>> IN('park','forest','grass','farmyard','farm','farmland','wood','meadow','village_green','recreation_ground')
>>>>>> THEN 'landusee' WHEN amenity in
>>>>>> ('university','school','college','library','fuel','parking','cinema','theatre','place_of_worship','hospital')
>>>>>> THEN 'amenityy' END AS stylegroup FROM planet_osm_polygon where (leisure is
>>>>>> not null) or (landuse is not null) or (amenity is not null)) AS data) as
>>>>>> nullidq where "way" && ST_GeomFromText('POLYGON((8116389.75422228
>>>>>> -1276192.28146022,8116389.75422228 3467795.44203122,12860377.4777137
>>>>>> 3467795.44203122,12860377.4777137 -1276192.28146022,8116389.75422228
>>>>>> -1276192.28146022))',900913)
>>>>>> 2019-03-06 11:24:14.911 UTC [2617] parsis at asiadb LOG:  could not
>>>>>> 2019-03-06 11:24:14.911 UTC [2617] parsis at asiadb STATEMENT:  select
>>>>>> WHEN leisure in
>>>>>> 2019-03-06 11:24:14.911 UTC [2592] parsis at asiadb FATAL:  connection
>>>>>> to client lost
>>>>>> 2019-03-06 12:08:25.564 UTC [3362] parsis at asiadb STATEMENT:  select
>>>>>> ST_AsBinary(ST_Force2D("way"),'NDR') as geom,"nullid"::text from (select *,
>>>>>> NULL as nullid from ( SELECT way FROM planet_osm_polygon WHERE (waterway IN
>>>>>> ('riverbank')) OR ("natural" IN ('water')) OR (landuse IN ('basin',
>>>>>> 'reservoir')) ) AS data) as nullidq where "way" &&
>>>>>> ST_GeomFromText('POLYGON((-20228294.8225998
>>>>>> -20228294.8225998,-20228294.8225998 17723606.9653297,17723606.9653297
>>>>>> 17723606.9653297,17723606.9653297 -20228294.8225998,-20228294.8225998
>>>>>> -20228294.8225998))',900913)
>>>>>> 2019-03-06 12:08:25.564 UTC [3260] FATAL:  terminating connection due
>>>>>> to administrator command
>>>>>> 2019-03-06 12:08:25.564 UTC [3260] STATEMENT:  select
>>>>>> 2019-03-06 12:08:25.564 UTC [3261] FATAL:  terminating connection due
>>>>>> 2019-03-06 12:08:25.564 UTC [3261] STATEMENT:  select
>>>>>> 2019-03-06 12:08:25.564 UTC [3363] FATAL:  terminating connection due
>>>>>> 2019-03-06 12:08:25.564 UTC [3363] STATEMENT:  select
>>>>>> 2019-03-06 12:08:25.570 UTC [1535] LOG:  worker process: parallel
>>>>>> worker for PID 3255 (PID 3261) exited with exit code 1
>>>>>> worker for PID 3362 (PID 3363) exited with exit code 1
>>>>>> worker for PID 3255 (PID 3260) exited with exit code 1
>>>>>> 2019-03-06 12:08:25.609 UTC [3426] parsis at asiadb LOG:  could not
>>>>>> 2019-03-06 12:08:25.609 UTC [3426] parsis at asiadb STATEMENT:  select
>>>>>> "admin_level"::text,ST_AsBinary(ST_Force2D("way"),'NDR') as
>>>>>> geom,"nullid"::text from (select *, NULL as nullid from (select * from
>>>>>> planet_osm_line where admin_level IN('2') and boundary IN
>>>>>> ('administrative') and way NOT IN (SELECT way FROM planet_osm_line where
>>>>>> admin_level IN('2') and boundary like 'administrative' and (tags->'dispute'
>>>>>> = 'yes' or tags->'ISO3166-1' IN ('IN','CN','PK') or way IN(select way from
>>>>>> in_cn_ignored_border)))) AS data) as nullidq where "way" &&
>>>>>> 2019-03-06 12:08:25.609 UTC [3426] parsis at asiadb FATAL:  connection
>>>>>> to client lost
>>>>>> Regards,
>>>>>> Parsis Presswala
>>>>>> On Wed, Mar 6, 2019 at 6:35 PM Yves Jacolin <
>>>>>>> Hello,
>>>>>>> Did you try to curl the request and see what happens: timeout, etc.
>>>>>>> If so, try to get some log (mapserver or postgresql log) and see where is
>>>>>>> the bottleneck.
>>>>>>> Y.
>>>>>>> Le mer. 6 mars 2019 à 13:58, parsis presswala <
>>>>>>>> Hello,
>>>>>>>> I am getting following error while generating tiles. I can't get
>>>>>>>> the reason of this error. I an using mapcache to generate tiles.
>>>>>>>> failed to seed tile z10,x645,y510:
>>>>>>>> curl failed to request url
>>>>>>>> http://13.126.201.198/cgi-bin/mapserv?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&STYLES=&BBOX=5201998.739765%2c-81328.655306%2c5795150.079258%2c511822.684187&WIDTH=3880&HEIGHT=3880&FORMAT=image%2fpng&SRS=EPSG%3a3857&LAYERS=osm_new_admin%2cosm_new_adminocean%2cosm_new_landusages%2cosm_new_water%2cbuildings%2caeroway%2cosm_new_waterways%2cosm_new_railways%2cplanet_osm_roads%2cplanet_osm_roads_line%2cosm_new_railways1%2ccountry_line%2ccountry_line_claim%2cstate_line%2cmotorway_label%2cmainroad_label%2cminorroad_label%2cosm_new_railways_symbol%2cplace-country%2cplace-state%2cplace-city%2cplace-town%2cplace-Suburb%2cplace-village%2cplace-locality%2carea_label%2caerodrome_label%2cwaterway_label%2cwaterarea_label%2cpoi_pointlabel&MAP=%2fhome%2fubuntu%2fworldmap%2fasiamap.map
>>>>>>>> : Operation timed out after 600000 milliseconds with 0 bytes received
>>>>>>>> aborting seed as 100.0% of the last 1000 requests failed
>>>>>>>> seeded 225 tiles, now at z10 x660 y510
>>>>>>>> seeded 2 metatiles (450 total tiles, 450 non-empty tiles) in 1201.8
>>>>>>>> seconds at 0.4 tiles/sec (0.4 non-empty tiles/sec)
>>>>>>>> If anyone could help me with this, it would be greatly appreciated.
>>>>>>>> Regards,
>>>>>>>> Parsis Presswala
>>>>>>>> _______________________________________________
>>>>>>>> mapserver-users mailing list
>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>>>>> Yves Jacolin
>>>>>>> Training and support manager - Team Manager
>>>>>>> Camptocamp
>>>>>>> Tel (France) : +33 4 58 48 20 43
>>>>>>> Tel (Switzerland) : +41 21 619 10 43
>>>>>>> Mob. : +33 6 18 75 42 21
>>>>>>> email : yves.jacolin at camptocamp.com
>>>>>>> http://www.camptocamp.com
>>>>> Yves Jacolin
>>>>> Camptocamp
>>> Yves Jacolin
>>> Camptocamp
> Yves Jacolin
> Camptocamp
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190306/3a4fa6cc/attachment.htm>
More information about the MapServer-users mailing list
