[mapserver-users] Possible bug?: msSmallCalloc(): Out of memory allocating -2732555844 bytes.
Alex G.
Xander84_88 at hotmail.com
Thu Mar 21 07:07:33 PDT 2019
I am reciving an error when mapserver try to show an *ecw file.
Below I have attached logs, test, and programs versions:
thank you in advance.
**Mapserver log :**
[Wed Mar 20 12:34:33 2019].161760 CGI Request 3 on process 930
[Wed Mar 20 12:34:33 2019].165160 msDrawMap(): rendering using outputformat named png (AGG/PNG).
[Wed Mar 20 12:34:33 2019].165209 msDrawMap(): WMS/WFS set-up and query, 0.000s
[Wed Mar 20 12:34:33 2019].165297 msDrawRasterLayerLow(ecw-test): entering.
[Wed Mar 20 12:34:33 2019].166044 msDrawRasterLayerLow(): Unable to access file. Corrupt, empty or missing file '/var/www/apps/ejercito/data/ecwtest/Mosaico_SPOT_2010_Canarias.ecw' for layer 'ecw-test'. `/var/www/apps/ejercito/data/ecwtest/Mosaico_SPOT_2010_Canarias.ecw' not recognized as a supported file format.
[Wed Mar 20 12:34:33 2019].166073 msDrawMap(): Image handling error. Failed to draw layer named 'ecw-test'.
[Wed Mar 20 12:34:33 2019].166125 mapserv request processing time (msLoadMap not incl.): 0.004s
[Wed Mar 20 12:34:33 2019].166142 msFreeMap(): freeing map at 0x5634ec628b60.
**shp2img -m /etc/mapserver/ejercito.map -l cecaf_cnv_1M -o test.png**
**gdalinfo /var/www/apps/ejercito/data/ecwtest/Mosaico_SPOT_2010_Canarias.ecw**
Driver: ECW/ERDAS Compressed Wavelets (SDK 3.x)
Files: /var/www/apps/ejercito/data/ecwtest/Mosaico_SPOT_2010_Canarias.ecw
/var/www/apps/ejercito/data/ecwtest/Mosaico_SPOT_2010_Canarias.ecw.aux.xml
Size is 23262, 9022
Coordinate System is:
PROJCS["NUTM28",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AXIS["Lat",NORTH],
AXIS["Long",EAST],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-15],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
Origin = (188288.698917730507674,3241075.270048933103681)
Pixel Size = (20.000000000000000,-20.000000000000000)
Metadata:
COLORSPACE=RGB
COMPRESSION_RATE_TARGET=1
VERSION=2
Corner Coordinates:
Upper Left ( 188288.699, 3241075.270)
Lower Left ( 188288.699, 3060635.270)
Upper Right ( 653528.699, 3241075.270)
Lower Right ( 653528.699, 3060635.270)
Center ( 420908.699, 3150855.270)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
Description = Red
Overviews: 11631x4511, 5815x2255, 2907x1127, 1453x563, 726x281, 363x140
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
Description = Green
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
Description = Blue
**mapserv -v**
MapServer version 7.0.4 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
**gdalinfo --version**
GDAL 2.3.3, released 2018/12/14
**libecwj2-3.3**
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190321/4162396e/attachment.html>
