[mapserver-users] 7.4.0-rc1 available for testing -> segmentation fault in php-cli
GOGIS Dieter Zuberbühler
dieter.zuberbuehler at gogis.ch
Mon May 6 06:06:42 PDT 2019
Dear Mapserver Developers,
i could fix this issue only by downgrading to php7.2. Here, everything
is fine...
Hint: it's maybe a libssl dependency problem
libssl-dev : Depends: libssl1.1 (= 1.1.0g-2ubuntu4.3) but 1.1.1b-
1+ubuntu18.04.1+deb.sury.org+1 is to be installed
=> perhaps this will be fixed for future releases...
Thanks anyway!
Dieter
> i'm developing a custom php/mapscript application since more than ten
> years and was waiting for the php7.x mapscript support to upgrade my
> application. now i have troubles with the php-cli calls that i need
> for
> precaching/processing several things.
> I could build the php_mapscript.so module and in libapache2-mod-php
> everything works as expected. But in the php-cli (same version) i get
> a
> segmentation fault processing a querytemplate:
> @$oMap->queryByRect($my_extent); //this is fine in both php
> $result = $oMap->processquerytemplate(array(),false); //this fails in
> php-cli
> GNU Debugger output:
> Program received signal SIGSEGV, Segmentation fault.
> 0x00005555557ff8aa in zend_hash_internal_pointer_reset_ex ()
> (gdb) bt
> #0 0x00005555557ff8aa in zend_hash_internal_pointer_reset_ex ()
> #1 0x00007fffe78cc04d in mapscript_extract_associative_array ()
> at /usr/lib/php/20180731/php_mapscript.so
> #2 0x00007fffe78c7784 in zim_mapObj_processQueryTemplate ()
> #3 0x000055555587abce in execute_ex ()
> #4 0x000055555587bcb3 in zend_execute ()
> #5 0x00005555557ece22 in zend_execute_scripts ()
> #6 0x000055555578ce70 in php_execute_script ()
> #7 0x000055555587e18c in ()
> #8 0x000055555564490b in ()
> #9 0x00007ffff5c29b97 in __libc_start_main (main=
> 0x5555556444f0, argc=9, argv=0x7fffffffe4f8, init=<optimized
> out>,
> fini=<optimized out>, rtld_fini=<optimized out>,
> stack_end=0x7fffffffe4e8)
> at ../csu/libc-start.c:310
> #10 0x0000555555644aaa in _start ()
> The system is where i run the application is Ubuntu 18.04LTS with the
> current php7.3
> The Query is based on postgis layers.
> Any Hint?
> Thanks in advance,
> Dieter
More information about the MapServer-users
