[mapserver-users] WCS 2.0.1 sends multipart response for ascii grid format
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Thu May 9 04:03:14 PDT 2019
I thought I could resolve the problem by setting
CONFIG "GDAL_PAM_ENABLED" "NO"
Unfortunately nothing changed.
-Jukka Rahkonen-
Lähettäjä: Rahkonen Jukka (MML)
Lähetetty: keskiviikko 8. toukokuuta 2019 18.53
Vastaanottaja: Mapserver-Users (mapserver-users at lists.osgeo.org) <mapserver-users at lists.osgeo.org>
Aihe: WCS 2.0.1 sends multipart response for ascii grid format
I have Mapserver 7.2.1 and outputformat defined as
OUTPUTFORMAT
NAME AAIGRID
DRIVER "GDAL/AAIGRID"
MIMETYPE "application/x-ascii-grid"
IMAGEMODE FLOAT32
EXTENSION "grd"
FORMATOPTION "SIGNIFICANT_DIGITS=5"
END
The WCS 2.0.1 GetCoverage request is sending the response as multipart.  The first part is the ASCII grid and it is followed by these two parts
--wcs
Content-Type: application/octet-stream
Content-Description: coverage data
Content-Transfer-Encoding: binary
Content-ID: coverage/out.grd.aux.xml
Content-Disposition: INLINE; filename=out.grd.aux.xml
<PAMDataset>
  <Metadata>
    <MDI key="TIFFTAG_RESOLUTIONUNIT">2</MDI>
    <MDI key="TIFFTAG_XRESOLUTION">72.000000</MDI>
    <MDI key="TIFFTAG_YRESOLUTION">72.000000</MDI>
  </Metadata>
</PAMDataset>
--wcs
Content-ID: coverage/out.prj
Content-Disposition: INLINE; filename=out.prj
PROJCS["ETRS89_TM35FIN_E_N",GEOGCS["GCS_ETRS_1989",DATUM["D_ETRS_1989",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",27],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
Is there a way to get rid of the last parts of the response?
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190509/a8f2178e/attachment.htm>
More information about the MapServer-users mailing list
