[mapserver-users] transparency with php mapscript
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu May 16 04:47:55 PDT 2019
Hi Sven,
As you know, all methods and functions are now listed in the SWIG API
reference document when using MS4W 4.0, and in the layerObj methods
section you can see a setOpacity() function
(https://mapserver.org/mapscript/mapscript.html#layerobj-methods).
Another trick is to open the local included file
"C:/ms4w/apps/phpmapscriptng-swig/include/mapscript.php" in your text
editor and search for "opacity" or "setOpacity" there, just to confirm
with your local installation of MS4W.
Recently another MS4W user asked about opacity, so I had created a test
script showing setOpacity() in action with SWIG MapScript:
https://ms4w.com/trac/wiki/SWIGMapScriptNewLayer
However, I admit that that example script is long and opacity is kind of
hidden in the code, so I have created another example for you at:
https://ms4w.com/trac/wiki/SWIGMapScriptOpacity which takes an existing
layer and adds a COMPOSITE object with the command:
// set opacity (actually creates a new COMPOSITE object)
$oPolyLayer->setOpacity(40);
I hope that makes it more clear.
-jeff
Thank you for using MS4W.
"MS4W: open doors as well as windows"
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2019-05-16 5:29 AM, Sven Schroeter wrote:
> Hello,
> I test current php mapscript versions under Windows and try to give a
> layer transparency.
> With mapserver versions < 7 this was possible:
> $layer_poly->opacity = 68;
> With the version MS4W 3.3.1 with Mapserver > 7 and PHP Mapscript it
> works like this:
> $layer_poly->updateFromString('LAYER COMPOSITE OPACITY 68 END END');
> In the new version MS4W 4.0.0 with the SWIG API I tried the following
> variants:
> $layer_poly->setOpacity(68);
> In all variants no error message, but also no transparency.
> Any ideas?
> Thanks Sven
More information about the MapServer-users
