[mapserver-users] transparency with php mapscript
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed May 22 05:49:13 PDT 2019
Hi Sven,
You found a good one. It took me some time to figure out what is happening.
In fact this is due to MS4W 4.0.0 being compiled with Pixman support;
unfortunately I had hit this back in 2016 and removed Pixman for that
reason. Here we are again though :) I'll remove Pixman for the next
MS4W 4.0.1 release. Follow along the progress at
https://ms4w.com/trac/ticket/218
Thanks for reporting this.
-jeff
Thank you for using MS4W.
"MS4W: open doors as well as windows"
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2019-05-22 4:53 AM, Sven Schroeter wrote:
> Hi all,
> I'm fighting with the SWIG PHP MapScript Opacity again and found a very
> strange behavior.
> Here is my test script:
> include("../includes/phpmapscriptng-swig/mapscript_70400.php");
> $map = new mapObj(MAPFILE_PATH.'test.map');
> // set image format
> $map->selectOutputFormat("image/jpeg");
> $oRasterLayer = $map->getLayerByName('tk_rlp_tms_grau');
> $oPolyLayer = $map->getLayerByName('grenzen_vg');
> $oRasterLayer->setOpacity(10);
> $oRasterLayer->status = MS_ON;
> $oPolyLayer->setOpacity(30);
> $oPolyLayer->status = MS_ON;
> // set image size
> $map->setsize(1000,768);
> $map->setextent(300497,5495624,366043,5558489);
> // Bild im MapServer IMAGEPATH abspeichern.
> $image = $map->draw();
> //Bildname, Extension und Pfad
> $picname = md5(rand());
> $picext = ".jpeg";
> $picpathname = MS_TMP_PATH.$picname.$picext;
> $mapimage = $image->save($picpathname,$map); //URL
> $imgurl = MS_TMP_URL.$picname.$picext;
> //header('Location: '.$imgurl);
> echo '<img src="'.$imgurl.'" border="1">';
> If I set the width of the image to a number with 2 zeros at the end
> everything works fine.
> e.g. $map->setsize(800,814);
> or $map->setsize(1000,768);
> as soon as I change the value for the width of the image it often
> doesn't work anymore and the layers don't have transparency anymore.
> e.g. $map->setsize(801,814);
> or $map->setsize(1011,768);
> It is extremely difficult to see a pattern here.
> All variants work with the old Mapscript.
> Is this a bug?
> Thanks + Greeting
> Sven
