[mapserver-users] mapcache seed speed optimization
Yves Jacolin
yves.jacolin at camptocamp.com
Fri Nov 8 05:42:03 PST 2019
Sebastiano,
Some though in my mind:
* –n 20000 : do you really have 2'000 CPU on your WMS server? if not, it
could be worst than better, flooding your WMS server.
* what is the bottleneck? If WMS server is slow you can't make MapCache
faster, you should optimise WMS Server. Multi-domain can help, data
improvement, etc. also.
* Does your WMS is on the same server? same network? Does you network fast
enough?
* metatile can help definitively!
* "we use sqlite as a cache method" => I don't know if sqlite is really
fast or not, but this could be another bottleneck :)
What do you mean exactly by improve seed speed? :) This is matter of
personal point of view some time.
Y.
Le ven. 8 nov. 2019 à 13:43, Sebastiano Laini <
Sebastiano.Laini at buchanancomputing.co.uk> a écrit :
> Hi all,
> I’m evaluating new stacks but seems that I’m stuck with mapserver and
> mapcache due to the input source of our maps, so I’m trying to improve the
> speed of the mapserver/mapcache stack and what I cannot improve is the seed
> speed.
> The –n and –p parameters seems to be useless.
> *-n | –nthreads*: number of parallel threads that should be used to
> request tiles from the WMS source. The default is 1, but can be set higher
> if the WMS server can withstand parallel requests. (As a rule of thumb, the
> value chosen here should never be much higher than the number of CPUs on
> the WMS server.)
> *-p | –nprocesses*: number of parallel processes that should be used to
> I’ve tried to use –n 20000 and –p 60000 but for some reason the CPU load
> is max 100% in 1 core, no way to make it use more power and speed up the
> seed process.
> Max memory used is 470MB between Centos 7 (with all the services running)
> and the seed process.
> I’ve setup apache to use HTT/2 and it make quite a difference when the
> cache is already seeded but during the seed process doesn’t seems to be
> affected.
> My MapServer build is:
> ./configure \
> --with-ogr=/usr/local/bin/gdal-config \
> --with-gdal=/usr/local/bin/gdal-config \
> --with-wfsclient \
> --with-wmsclient \
> --with-wfs \
> --enable-debug \
> --with-curl-config=/usr/bin/curl-config \
> --with-proj \
> --with-jpeg \
> --with-freetype \
> --with-postgis=/usr/pgsql-9.3/bin/pg_config \
> --with-geos=/usr/local/bin/geos-config
> I know there is mapserver 7 and yet I’m using 6 for the test.
> While the MapCache is:
> cmake -DCMAKE_PREFIX_PATH="/usr/bin/sqlite3" \
> -DWITH_SQLITE=1 \
> -DWITH_BERKELEY_DB=0 \
> -DWITH_TIFF=0 \
> -DWITH_GEOTIFF=0 \
> -DWITH_FCGI=0 \
> -DWITH_PCRE=0 \
> -DWITH_PIXMAN=1 \
> -DWITH_OGR=1 \
> -DWITH_GEOS=1 \
> MapCache is the latest version and this is my mapcache.xml file, we use
> <cache name="cache_sqlite" type="sqlite3">
> <dbfile>/home/www/html/maps/cache/{tileset}/{grid}/{z}/{x}-{y}.sqlite3</dbfile>
> <xcount>10000</xcount>
> <ycount>10000</ycount>
> <pragma name="max_page_count">1573741823</pragma>
> </cache>
> <tileset name="bccache">
> <source>bcmaps</source>
> <cache>cache_sqlite</cache>
> <grid>bcgrid</grid>
> <format>PNG</format>
> <metatile>16 16</metatile>
> <metabuffer>0</metabuffer>
> <expires>2628000</expires>
> </tileset>
> <grid name="bcgrid">
> <metadata>
> <title>BC custom grid</title>
> </metadata>
> <srs>EPSG:27700</srs>
> <size>256 256</size>
> <extent>0 0 700000 1250000</extent>
> <resolutions>70 28 14 7 2.8 1.4 0.7</resolutions>
> </grid>
> <format name="mypng" type="PNG">
> <compression>best</compression>
> </format>
> <service type="wms" enabled="true">
> <full_wms>assemble</full_wms>
> <resample_mode>bilinear</resample_mode>
> <format>mypng</format>
> <maxsize>4096</maxsize>
> </service>
> I’ve also tried to use –DWITH_MAPSERVER but seems that the integration is
> not working and they doen’t care?
> https://github.com/mapserver/mapcache/issues/169 this issue was open 2
> years ago and still open, not even a reply from the developers.
> How can I improve the seed process?
> Should I increase the maxsize and metatile to requests more tiles and
> cache faster?
> Regards,
> Sebastiano Laini
> Web Developer
> Buchanan Computing
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Yves Jacolin
Training and support manager - Team Manager
Camptocamp
Tel (France) : +33 4 58 48 20 43
Tel (Switzerland) : +41 21 619 10 43
Mob. : +33 6 18 75 42 21
email : yves.jacolin at camptocamp.com
http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20191108/b7cece0a/attachment-0001.html>
